Results 1 to 4 of 4
    Aug 2012
    5
    Need help on what monitor cable I need
    So my monitor has a VGA plugin and a DVI-D one.
    The graphics card I'm getting has a DVI and HDMI.
    Here is a link to it:
    Newegg.com - EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    My question is basically can I plug in VGA to DVI or do I need to do DVI-D to DVI (a link to what I need would be nice if it isn't to much to ask for).
    I've looked everywhere and I'm not sure if anything I found is what I need. It's hard to find what I'm looking for when I'm not sure what I need.
    Minnesota
    17,373
    why would you think you could plug VGA into DVI when their both completely different physical connections? Simple, and I do mean a very SIMPLE google search would reveal that, heck just plain observations in person would tell you that.
    There are DVI to VGA adapters, but if your monitor has a DVI-D connector, just use the DVI-I connector on the video card, problem solved.
    DVI-D is a Digital ONLY Signal, DVI-A is Analog Only, and DVI-I Is capable of either/or.
    Digital Visual Interface - Wikipedia, the free encyclopedia
    Aug 2012
    5
    No I just meant VGA to DVI (like one side of the cable is VGA and the other side is DVI) not plugging in the VGA side into the DVI.
    I know that the plugins have different physical connections.
    I wasn't asking if the VGA part of the cord would fit in the DVI plugin.
    Thank you for clearing things up in the second paragraph though.
    Also I only have a VGA to VGA monitor cable but will I still have an issue? Or will the adapter it comes with solve the problem.
    Jan 2003
    Outside the box
    8,489
    4
    If you want the best possible picture you'll want to get a DVI cable. If you just want to make due the card comes with a DVI-VGA adapter. So you could use your VGA cable and connect up your monitor that way and then there would be no need to buy anything extra. If it were me I'd spend the extra couple dollars and get a new cable, they are nice to have on hand for down the road anyways.
  1. Need a Monitor Cable
    By af240 in forum Graphics Cards and Displays
    Last Post: May 28th, 2009, 12:53 PM
  2. Monitor Cable Help!
    By af240 in forum Technical Support
    Last Post: May 27th, 2009, 02:57 PM
  3. Cable Box to PC Monitor ?
    By MegalosSkylaki in forum Multimedia and Audio
    Last Post: May 26th, 2006, 12:45 AM
  4. Monitor Cable
    By RCN_Moose in forum Graphics Cards and Displays
    Last Post: July 13th, 2002, 01:01 AM
