October 23rd, 2012, 01:17 AM #1Junior Member
- Oct 2011
- 14
Leadtex Nvidia GTX 550 TI problem >_<
Hey guys..I have encouter some problem with my new card..Just bought it 3 days ago and it work nicely for an hour..After that,it keep crashing and shutdown by itself..my psu also blowing up a few days ago..But today it shows some weird error.. GTX 550 Ti Error - YouTube . As u can see,after some crash occur,the graphic started being weird and it seem like its stop working.. I tried to unistall and clean it using driver sweeper and etc but it didnt work..Does this mean my card were offically broken?
-My PC Spec-
Processor: AMD Phenom II X3 710 2.61 GHz
Ram : 4gb DDR2 Kingston (2gbx2piece)
Graphic : Leadtex Nvidia GTX550 Ti 1gb
Monitor : Acer V203H
Power Supply: Exploit Model:ATX-500w
Mobo : Asus m2n68-am plusLast edited by free4meis; October 23rd, 2012 at 01:33 AM.
October 27th, 2012, 04:10 PM #2Member
- Jun 2008
- 313
Having glitches on post is definitely either the card or the slot. I had an 8600GT a few years back that did the same thing (glitches on post, disabled card in the device manager). I put another card in the slot and while it didn't act up in the same way, it still acted up. I moved to the second slot and it was fine. Since your board has only 1 pcie slot for graphics, I would be either trying to test another card in the slot, or that card in another machine. But I'm almost 100% certain that the board or the card is the problem (most likely the card).
October 27th, 2012, 09:23 PM #3Junior Member
- Oct 2011
- 14
Yea,the old card work perfectly for me.Tested on my bro pc and yea,the card still being the same.Probaly my card problem.Any idea how to fix it?? or should i exchange it for a new one?
October 27th, 2012, 10:23 PM #4Member
- Jun 2008
- 313
Exchange. You'd need a logic probe and spec details to even locate the problem, much less fix it. Usually glitches like that are related to the vram.
October 29th, 2012, 02:24 AM #5Junior Member
- Oct 2011
- 14
Was thinking on Sapphire 7750 or GT 640...which one is better?or do u have any suggestion?
October 29th, 2012, 03:11 AM #6
640 can't even compete with the 7750.
your 550 Ti would even beat the 640.
Radeon 7770's have come down in price, can now get them for roughly what the 7750 initially went for, if you can afford one, I'd recommend the 7770 instead.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
October 31st, 2012, 02:36 AM #7Junior Member
- Oct 2011
- 14
Thanks for suggestion..Imma grab that 7770..^_^ thanks for all who spending a time and helping me here.
Request thread to be close
October 31st, 2012, 02:54 AM #8
your welcome.
Post back on how it goes.
Will leave thread open till then at least, usually don't close a thread unless its really needed, or too many users reviving the old topics.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
Problem with new drivers with an Nvidia GTX-295
By ocgamer in forum Graphics Cards and DisplaysReplies: 5Last Post: May 27th, 2012, 10:44 PM -
gtx 460 or 550 ti?
By boiler149 in forum Graphics Cards and DisplaysReplies: 23Last Post: April 17th, 2012, 11:55 PM -
GeForce GTX 550 ti
By HelpPl0x in forum Technical SupportReplies: 2Last Post: December 26th, 2011, 01:26 AM -
Nvidia gtx 470/gtx 480 to have disabled Cores.
By no1_vern in forum Graphics Cards and DisplaysReplies: 0Last Post: March 23rd, 2010, 10:54 AM -
Nvidia GTX 260 problem
By AstroExpo in forum Technical SupportReplies: 18Last Post: November 25th, 2009, 11:32 AM
Hi Guys, Weekend is here. Enjoy latest movies with some best shows: Transformers Prime Season 3 Episode 6 Game Of Thrones Season 3 Episode 8 Watch Star Trek Into Darkness Online Watch Fast and...
Enjoy your fav one
