moniter problem or video card problem?  | |
March 14th, 2003, 08:39 PM
this really weird thing just started to happen to my computer yesterday. the problem is........ the whole screen just shifts slightly to the right/left and then returns this happens about every 10-20 seconds. is this a moniter problem? or could it be that my video card is gone bad?
moniter: ibm c72 (all drivers installed)
video card: powered by ATI radeon ve 64mb
other specs:
asus p4t-e
256 mb ram
40 gb HD
sb live 5.1
please help. |
March 14th, 2003, 08:43 PM
ok i juist found out something else. when i bring up the menu for setting the contrast brightness ect (with the buttons on the moniter), this menu doesn't move with the whole screen. so im guessing maybe its a video card prob? |
March 15th, 2003, 01:32 PM
March 15th, 2003, 01:36 PM
| | Free Thinker
I've been having a similar problem. My second monitor screen gets very narrow and tall suddenly. Then it comes back to normal after a bit. In my case I think I'm short on power. Too many things plugged into the wall socket. Are you running a lot of stuff on one circuit?
You can't fix stupidity.
March 15th, 2003, 01:48 PM
yeah i have one of those extension outlet thingys and it has like 8 plugs. i have everything connected on it. but..... this type of problem never occurred before and ive had it the same way for more then a year. |
March 15th, 2003, 01:56 PM
| | Free Thinker
Same here. Mine worked fine until yesterday. But I had removed one PC and set up another. The second PC must draw more power than the first. Just for laughs try plugging the monitor into a different circuit. Or else unplug non-essential stuff for a bit.
Also, try a different power cord or a lower resolution. If you have access to a different PC or monitor, try swapping things around. |
March 15th, 2003, 09:51 PM
i tried anoter power outlet, still the same. noe it has increased and does it even more then before. i don't have another moniter or anoter video card that i could try. |
March 15th, 2003, 10:07 PM
| | Free Thinker
You could try uninstalling the vid card drivers and then reinstall them after a reboot. |
