Thread: 9700 pro softmod to 9800 pro
June 16th, 2003, 08:05 AM #1Member
- Jun 2003
- Location
- Lansdowne, ON
- 110
Can anyone give me more info on softmods for the 9700 pro? I have a Built by ATI AIW 9700 PRO 128mb. Also any overclocking experience/advice would be appreciated.
June 16th, 2003, 09:03 AM #2
for what that card cost i wouldn't chance doing a mod on it . if you bake it thats alot of jack your out .
June 16th, 2003, 02:35 PM #3
Lighten up Omardeth. You sure are squemish. Livin on the edge is what its all about.
June 16th, 2003, 02:53 PM #4
Cant remember what thread I got this from but this link was attached.
http://www.maxdownloads.com/~ian/wizzard/
Go through it, download the appropriate file (look closely, it's not clearly labeled) and there is another link to a forum that talked some about what to do with it.
Hope this helps.
June 16th, 2003, 03:11 PM #5
I didn't know there was a mod to go from 9700 pro to 9800 pro, considering they are two different architectures.
I did the 9500 pro to 9700 pro mod using the Warp 11 bios...the 9500 and the 9700 are architecturally the same with the exception of the memory bus. The mod works because it re-enables the additonal 4 rendering pipelines on the 9500 pro that were disabled by ATI, and it also unlocks the bios to enable overclocking. But again, it only worked because the two cards are so similar in architecture...won't work on a 9600 pro, the 9500's replacement, because it is a completely new architecture.
So, you can see what can be gained from a 9500 pro to a 9700 pro mod...the 4 additional pipelines and the ability to overclock...what do you hope to gain from modding the 9700 to a 9800? (If it's even possible?)
In response to Omar's concern...there is always the chance you could hose the card...it didn't happen to me...but if you do find that there's a benefit to modding the 9700 to a 9800, I say go for it, take the risk...everything in life is a learning experience...both good and bad :-)
June 16th, 2003, 03:20 PM #6
yeah, im not sure if that site was successful with the 9700-9800 softmod. Initially, I thought it was a typo but one of those downloads seem to be present just for this situation. As for their ability to do so by virtue of the engineering, I have no idea.
June 16th, 2003, 04:10 PM #7
The softmod is possible for the 9700 pro to 9800. Remember it's a software mod. I did it to mine, but, it doesn't work with the latest drivers.
June 16th, 2003, 04:21 PM #8i agree .with a 45$ cpu . but a 300$ + video card .. i wouldn't take the chance . the difference in preformance isn't that much in the real world . in benchmarks yes it is but if you had 2 pc's side by side and one had a 9800pro and the other had a 9700 pro i don't think you could tell the difference just from looking at the display .Originally posted by tony_j15
June 16th, 2003, 05:31 PM #9
True. Using that philosophy a honda would perform as well as a lamborgini if they looked the same. The extra performance boost makes the game run faster, you saved the money you would have had to spent otherwise to get those speeds, and you have bragging rights.
June 16th, 2003, 05:50 PM #10
Still, it seems a lot better to mod a £50 cpu than a £350 gfx card. Is it really worth it?
_____
NuKeS
June 16th, 2003, 06:01 PM #11
thats my point nukes ..
thanks ..." If you kill a man you're a murderer ..... Kill many and you're a conquerer ....... Kill them all ... your a GOD...."
June 16th, 2003, 06:04 PM #12no thats comparing apples with oranges ...Originally posted by tony_j15
the difference between a 9700 pro and a 9800 pro aren't all that much in the real world .. well other than about 75-100$ in price difference .
but i agree you will have bragging rights . but i am old married and poor .. so i guess i see things alittle different .
June 16th, 2003, 06:24 PM #13but i am old married and poor .. so i guess i see things alittle different .
YEAH!
the mod that is done is only to improve your 3dmark scores, nothing more, in fact, its pretty much "cheating' you can get more done by using a program like powerstrip and jump your core and ram clocks by about 10%, and be just fine.
but in all reality i have mowed through 2 (working on 3) 9500->9700's because they keep coming to me dead
so in my experience, if you want a 400HP car, don't buy a 350HP and give it loud exhaust and a huge intake, it screams "el cheapo"
I prefer not to be stopped in the street just because someone decided my clothes were "wrong" or my hair was "too long". I do understand and partly agree with your point, but this was too much, IMO.
Do you think this was a legitimate...
