Results 1 to 5 of 5
    Sep 2003
    3
    Question gigabyte radeon 9200 vivo TV out problem
    HI,
    I have a gigabyte radeon 9200 vivo card and am unable to get the TV out option to work. I have the latest drivers & bios.
    As instructed, I have my TV connected (via the s-vid to composite adapter) to the card before turning on the computer, however only my main monitor is shown as being connected under the ATI display properties in xp.
    Can anyone offer any suggestions?
    THanks
    Senior Member DallasDon's Avatar
    Aug 2003
    The Promised Land
    832
    did you click the "extend my destop to this monitor" in the settings tab?
    Right click the wallpaper, click properties, settings tab: should show two monitors.
    Open the popup menu to monitor 2, click "Extend" the apply.
    If two monitors are not shown, you might need to install the DVI drivers from the cd that came with the card.
    Sep 2003
    3
    yes, but when I check the "extend my desktop" option, it unchecks itself when I click "apply".
    Augsburg, Germany
    5,584
    Check in the advanced properties for whether the TV set has been detected at all. Some don't have the electrical properties of the connection quite correct, and thus go undetected. ATi's latest drivers have a "force TV detection" switch right there to work around this problem.
    Sep 2003
    3
    The TV has not been detected at all.
    I don't seem to have a "force TV detection switch" even though I have downloaded the latest drivers from the gigabyte site.
    Should I be using drivers downloaded from elsewhere?
    Thanks kindly.
