graphics card problems
Currently Active Users: 1652
Discussions: 200,924, Posts: 2,379,117, Members: 246,290
Old September 26th, 2003, 12:14 AM   Digg it!   #1 (permalink)
I have just bought a PNY Technoligies Verto GeForce FX 5200 graphics card and when plugged into my pc, it will not boot. My motherboard is a PC400 P4 M925 series. Are they not compatible or am I doing something wrong?
weemoney is offline   Reply With Quote
Old September 26th, 2003, 12:36 AM     #2 (permalink)
its probably just not seating into the slot correctly..unplug the power supply..pull the card out and push it in firmly and try again.
JP
Old September 26th, 2003, 12:40 AM     #3 (permalink)
ragtop's Avatar
Yes, check to see if the card is seated fully, but if that's not the problem, some additional info is needed:
What exactly does the computer do when you try to boot??
What OS??
What card did you have before, or does that board have onboard video??
Did you uninstall the old video card drivers and remove it from device manager before shutting down and physically removing the old card??
ragtop is offline   Reply With Quote
Old September 26th, 2003, 12:59 AM     #4 (permalink)
My OS is Windows XP ,uh, you can hear the fans start but the boot screen wont start, my monitor wont engage. It has onboard graphics and I disabled them in the device manager and still nothing
Old September 26th, 2003, 01:15 AM     #5 (permalink)
ragtop's Avatar
Check in BIOS under PCI Plug&Play setup and see if Primary Graphics Adapter is set to "AGP". According to the manual, that should allow both the onboard video and the AGP slot card work simultaneously.
I didn't see any setting that allows you to completely disable the onboard video, but look around in BIOS, it might be there somewhere.
Just keep track of any changes you make in BIOS, so you can change them back again if necessary.
Good luck.
Old September 26th, 2003, 01:18 AM     #6 (permalink)
Thanks man. Could it be possible of my AGP slot being 1.0 instead 2.0 or higher as required for the graphics card, and how can I tell?
Old September 26th, 2003, 01:21 AM     #7 (permalink)
ragtop's Avatar
Thats a pretty new board - it supports up to AGP 4x, therefore it should be AGP 2.0 compliant.
Old May 22nd, 2004, 02:37 PM     #8 (permalink)
i have the same problem but my card is MSI Ge-force 5600 fx and Radeon 9600 pro 256, WHAT is going on. if some one can solve this please send e-mail and let me know asap. I've test almost everything, bios setting ... power supply ...
urza710 is offline   Reply With Quote
Old May 22nd, 2004, 02:45 PM     #9 (permalink)
Newbie
filipino's Avatar
disable the on board videocard on cmos setup press delete rapidly when booting up so you can enter the cmos setup also read your motherboard manual for reference..
did you hear a single beep when booting up? or a beep beep beep sound?
but most mobo with built in videocard automatically disable when you put a videocard on slot.
hope this helps
filipino is offline   Reply With Quote
Is It Just Me? (2862)
Obama the Muslim (14)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
