MOBILITY RADEON 7500 Problems
Currently Active Users: 1711
Discussions: 200,950, Posts: 2,379,462, Members: 246,312
Old December 9th, 2003, 02:25 PM   Digg it!   #1 (permalink)
I have a IBM Thinkpad T40, it has a MOBILITY RADEON 7500 graphics card, when i install the drivers for the graphics card and reboot it goes to a blue screen, and an error msg says "c0000415, Unknown hard error on start up everytime?
at the moment my laptop is practically useless because of this
Does anyone know how to solve it? i have tried all the newest drivers available.
Cheers
Coxy
coxy_rdfc is offline   Reply With Quote
Old December 9th, 2003, 03:32 PM     #2 (permalink)
blubomber's Avatar
Send a message via MSN to blubomber Send a message via Yahoo to blubomber
Which Operating System are you using?
Try booting into safe mode and remove the drivers. Did you load the Catalyst 3.9? If so, after you remove the drivers, install 3.8 or earlier. I have seen a few people, including myself, have problems with the 3.9 drivers.
Hope this helps you.
blubomber is offline   Reply With Quote
Old December 9th, 2003, 04:20 PM     #3 (permalink)
im using win XP pro, where can i get thr Catalyst 3.9 drivers?
Im not sure if i have tried them i have tried loads of drivers
Old December 9th, 2003, 04:34 PM     #4 (permalink)
Moderator
phenious's Avatar
Send a message via AIM to phenious
You need to find drivers for your mobility card on IMBs website. In general the only drivers that will probably work well with your laptop are the ones that your laptop manufacture put out. Hope that helps.
-: phenious :-
phenious is offline   Reply With Quote
Old December 9th, 2003, 04:36 PM     #5 (permalink)
tried the ones from the IBM web site for the T40 thinkpad. they are the drivers i originally tried they give the error mentioned
I have just tried the Catalyst 3.9 and 3.8 ones and they both result in the same error
Old December 9th, 2003, 05:34 PM     #6 (permalink)
Moderator
phenious's Avatar
Did you laptop come with a CD with the original drivers? That maybe your online luck... have you tried talking with IBM over e-mail or something?
-: phenious :-
Old December 9th, 2003, 06:09 PM     #7 (permalink)
I brought it 2nd hand cheap, and none of the hardware was installed on it, got all the drivers for everything from the IBM site, graphics card is the only thing with problems
Is it possible to buy and install a new graphics card for a laptop?
Old December 9th, 2003, 08:12 PM     #8 (permalink)
Moderator
phenious's Avatar
only if its an expandable and next to none are... i dont have much experience there...
-: phenious :-
Old December 10th, 2003, 12:01 PM     #9 (permalink)
blubomber's Avatar
Since it is a laptop, you are stuck with that video card. The video chip is integrated into the motherboard. You say that you are using XP pro, did you install XP your self or did you buy it with XP? If you just got the laptop and there is no info on it, you may want to try reinstalling windows XP.
How was the video before you installed the graphic drivers? How many different drivers have you used? The Catalyst 3.9 drivers are no good IMO because i have seen alot of people having problems with them.
Old December 10th, 2003, 12:14 PM     #10 (permalink)
Win XP was on it when i got it which as far as i can see was the original install, I was having problems installing the graphics card so i reinstalled win xp pro, but encountered the same problems.
The graphics before i install the drivers seem ok, but i cannot watch DVDs etc. I have used many drivers, i have downloaded various ATI Radeon 7500 drivers from different places, i started using the drivers from the IBM site that where supposed to be for the laptop but encounted the error mentioned, and the same has happened with the others i have tried.
Are there any other drivers i could use instead of the ATI Radeon ones?
The disrespect of Obama by Russian .. (39)
Is It Just Me? (2942)
Making Health Care Worse (177)
Regular Build (9)
Print spooler problem (15)
Dept. of HS: NSA 'Helped' Develop V.. (16)
Regular Build (9)
Internet Lost (3)
Virus advise (7)
EVGA 9800 gtx help with finding a goo.. (10)
Modern Warfare 2: Who Bought It? (62)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
