Results 1 to 10 of 10
    Nov 2003
    14
    Unhappy HElP!!!!!! Video Problems
    PLzz Help Me!! everytime i play counter strike i see these squares on my spray, smoke, black part where nades explode, when i scope, and on some textures, they are pretty big. They used to be small squares, they used to be the size of the pixles but now they are pretty big. This also happens in other games such as starwars jedi knight and call of duty. It used to work fine but i dont know what happened. It happens on all resolutions and i do not OC.
    im running on
    Dell
    2.6 MGz
    1 GB Ram
    256mb radeon 9800 xt
    i Have screen shots of what it looks like, but i cant post them because thier file size is too big. IF U THINK U CAN HELP PLZ REPLY AND I WILL EMAIL U THE SCREEN SHOTS SO U CAN HELP ME!!
    Dec 2002
    62
    What os and version of directx are you running ?
    Space for Sale! :p eagle1's Avatar
    La Isla del Encanto
    5,879
    Have you updated ATi Drivers?
    You can download the new Catalyst 3.10 Drivers from their website.
    Also, are you overclocking the card?
    boo!
    Ultimate Member ragtop's Avatar
    Milwaukee, WI
    1,627
    Make sure the cooling fan on the vid card hasn't failed. They sometimes do stuff like that when they overheat.
    Dublin,Ireland
    500
    type in the console,try them one at a time
    cl_particlefx "0"
    cl_fog "0"
    Nov 2003
    14
    reply
    i am using windows xp pro and i am running on the new direct x, i actually thin that the new direct x might have made it happen because when i installed it that was the time around i started having problems.
    Nov 2003
    14
    does anyone have any suggestions???
    Jul 2003
    1,253
    Did you try their new drivers?
    Nov 2003
    14
    Unhappy yea
    yes i just put the .310 cat on it. its still screwed up. what kinds of programs/accessories could mess it up?? When i put it on different resolutions the squares get smaller or bigger.when the resolution gets higher the squares get smaller.
    Nov 2003
    14
    Unhappy yea
    yes i just put the 3.10 cat on it. its still screwed up. what kinds of programs/accessories could mess it up?? When i put it on different resolutions the squares get smaller or bigger.when the resolution gets higher the squares get smaller.
