Using an HDTV as an monitor
Currently Active Users: 1505
Discussions: 200,952, Posts: 2,379,481, Members: 246,319
Old February 9th, 2004, 02:27 PM   Digg it!   #1 (permalink)
I was planning on getting a 32 inch high deffinition television and I was wondering if I could use it as a computer monitor? I know that a regular tevelision display is blurry, but I was wondering if a hdtv would work.
Kyle
Chaintech VNF3-250
1 gig Corsair pc3200
AMD64 3200+
Audigy2 ZS Gamer
ATI Radeon 9800Pro
2*80 gig Hitatchi Deskstar Raid 0
covana is offline   Reply With Quote
Old February 9th, 2004, 02:31 PM     #2 (permalink)
uh based upon what i know, even if the tv is HDTV, you would need a video card that supports like, HDTV output, the quality though, wont look too bad, of course on a monitor it will be a lot better, but you will need a large resolution (or something) for it
oh and you probably are only going to have an S-Video out, your best bet
extreme_gamer is offline   Reply With Quote
Old February 9th, 2004, 02:42 PM     #3 (permalink)
joker_927's Avatar
I'm wondering this too.
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
joker_927 is offline   Reply With Quote
Old February 9th, 2004, 02:47 PM     #4 (permalink)
that aint a lightsaber
tony_j15's Avatar
Send a message via ICQ to tony_j15 Send a message via AIM to tony_j15
If you are getting a HDTV, make sure its 1080i. Thats the best HDTV resolution, and should look pretty good hooked up to a comp. When shopping, look for a TV that has DVI or DB-15 connectors. S-video wont cut it. Of course, you will need a good 3D card that has whatever output your TV requires. Also remember that 1080i=1920x1080 resolution. Thats a lot of pixels to push, so make sure your card has the gumption to handle it.
tony_j15 is offline   Reply With Quote
Old February 9th, 2004, 06:22 PM     #5 (permalink)
I mostly would like something bigger than my 19" monitor to play my dvd's and games on. I have a standard 27 inch tv and it is just too blurry and the picture quality is not good compared to my monitor. What is the best bet for me?
Old February 9th, 2004, 07:45 PM     #6 (permalink)
tony_j15's Avatar
Standard TV's only run at something like 640x480, not good at all. Your "best bet" depends mostly on the size of your wallet. The bigger the bucks, the more real estate you can have. Question: Where will you have the PC and TV set up at? If its the living room, any size set will do. If its at a desk, you'll need some sort of flat screen. You may want to ditch the idea of using a TV alltogather and get a big ol' LCD flat panel.
Old February 9th, 2004, 07:48 PM     #7 (permalink)
teengeek88's Avatar
Send a message via AIM to teengeek88 Send a message via Yahoo to teengeek88
make sure the TV has a PC and/or DVI input
teengeek88 is offline   Reply With Quote
Old February 9th, 2004, 07:54 PM     #8 (permalink)
(AKA) Nakamura
sweeper2's Avatar
hmmm I have been wondering to, If I hooked my pc up to my 51" HDTV using "s" video into one of my component hookups, it wouldn't look as good as my 19" CRT monitor?
ATI Radeon 9600 pro 128 video card
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old February 9th, 2004, 07:57 PM     #9 (permalink)
teengeek88's Avatar
not even close... that radeon probably has DVI out but does the HDTV.... the PC and DVI hookups to TVs make a big difference in images quality
Old February 12th, 2004, 07:25 PM     #10 (permalink)
(AKA) Nakamura
sweeper2's Avatar
I tried hooking up my pc...to my 51 " HDTV, used an "S" video cable from video card to one of the video "S" cable inputs, switched the tv over to that particular video input but got nothing but garbled image? How can I get the pc to hook to the tv?
9600 radeo pro 128
has 2 settings...monitor is #1 and then there is a sec. monitor, which I don't have hooked up?
want to try and see if it works before wife gets home..hehehe
Is It Just Me? (2943)
Print spooler problem (15)
SELLING FRESH,CVV,LOGINS,DUMPS,TRACKS.. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
