Results 1 to 9 of 9
    Member Sanman's Avatar
    Tilton,NH
    365
    car door stuck closed
    I have a '91 Celica GT and I can't get the passenger side door open. I put the window down and was able to look down inside and the linkage is still attached and working, but the door won't release from the catch. It has power locks and they seem to be working fine, I can hear them operating. The guy I bought it from said it worked fine when he had it, and he is a friend so I trust him. Does anyone have any tips on how I can get the door open? I appreciate any advice I can get to solve this problem.
    Member disciple's Avatar
    kennewick, washingto
    252
    Sounds like the latch in the door is not releasing which can be caused by a worn latch mechanisim or the linkage is not traveling far enough to depress latch to open lock can have same problem. At the shop we would remove inner door panel from inside and attempt to operate latch from inside door at this point you can spray WD40 on the latch and see if just sticky or you May have to pull handle if linkage is problem get a rod from the wrecking yard or alter the one you have. If you can remove door panel it will give you the ability to look at latch while its operating to detect problem or latch failure. The inner door panel is not to difficult to remove just take your time.
    Tilton,NH
    365
    The problem with that is the screws that hold the panel on can only be accessed with the door open. I was hoping there was some tool that could get in there and reach the mechanism. I know there are a few mechanics in this forum so I figured I would ask. I have a few other things to try out tomorrow. I may just have to bring it to my mechanic. Thanks for the reply, I will look again at the door panel and see if I can get enough room to squeeze my arm in there.
    Ultimate Member Chuckiechan's Avatar
    North Mexico
    18,672
    Try operating the locks and the latches while bumping the door inward from the outside. Maybe the gasket has some "squish" and will let the latch slide back.
    Bill Clinton: "I chose other women over Hillary. You should too!"
    Apr 2006
    0
    Did you ever fix this problem? I have same issue, with a 98 acura cl. Door is stuck shut, i cant open from key hole, outside, or inside the car. Cant pull panel off cause the door is shut. IDeas?
    Rock of Ages jokostel's Avatar
    Bismarck,ND
    27,538
    slim jim
    He who seeks vengeance must dig two graves. One for his enemy, and one for himself.-- Lao Tzu
    Jun 2010
    Acura 98 door wont open
    Quote Originally Posted by Sidewayz View Post
    I also have the same problem with my 98 Acura. Were you able to fix yours and if so how?
    Forerunner Shipuuden's Avatar
    Feb 2007
    Hueco Mundo
    3,044
    4
    Quote Originally Posted by wess7777 View Post
    High explosives dude.... High explosives..
    You people are you satisfied with this kind of world? I'm not.
    i took off back door to try to get a better angle on latch mechanism on front driver side door but the latch wont budge is there a part on latch i can try to free it with a screw driver of soom sort
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Involved in car wreck yesterday.
    By Xeroid in forum IMO Community
    Last Post: May 19th, 2004, 02:43 PM
  2. keeping my car door closed tight help
    By sixf00t4 in forum IMO Community
    Last Post: June 18th, 2003, 11:44 PM
  3. Grand Prix 4 patch released
    By Dudster in forum General Gaming Discussion
    Last Post: November 22nd, 2002, 09:00 PM
  4. Old classic car question
    By daveleau in forum IMO Community
    Last Post: July 30th, 2002, 11:51 PM
  5. Question for all you car buffs
    By GroundZero3 in forum IMO Community
    Last Post: December 5th, 2001, 01:31 AM
