Are the fittings for the gauges Metric or SAE ???? You'll probably need to install a"Tee" fitting where the original oil sensor was located and attach both sensors there. Since the Toyota will be metric, you may have to modify the Tee fitting to be able to hook it all up, but that's no big problem. Just need a tap to make thre right threads. Good Luck.
"To announce that there must be no criticism of the president, or that we are to stand by the president right or wrong, is not only unpatriotic and servile, but is morally treasonable to the American public." ---Theodore Roosevelt
