Go Back   Tech Support Forums - TechIMO.com > TechIMO Community > IMO Community
Fuel oil tanks?
Currently Active Users: 1830
Discussions: 200,510, Posts: 2,374,415, Members: 245,833
Old August 30th, 2005, 11:00 AM   Digg it!   #1 (permalink)
Indispensable Member
surreal's Avatar
Send a message via ICQ to surreal Send a message via AIM to surreal Send a message via Yahoo to surreal
Fuel oil tanks?
What do you look for when you inspect them? What do you do for maintenance?
I hear they get sludge in them.. do you clean that or ignore it??
Thanks...
sign me...
The Home Improvement Queen
surreal is offline   Reply With Quote
Old August 30th, 2005, 11:23 AM     #2 (permalink)
zen
zen's Avatar
1. Make sure they don't leak. Look for signs of leakage, before you fill!
2. Change filter every year, (usually when you get furnace serviced)
3. Do not run too low, the sludge at the bottom will cause havoc.
Ignore it.
SLUDGE--WHAT IS IT?
In your storage tank you have two materials to combat; water and particles of solid chemical compounds, commonly called sludge. Water is due mostly to condensation and leaking manholes, and occasionally from the oil supplier. Regardless, it is always found either on the tank bottom or stratified at different levels throughout the oil. Modern refining cracking processes produce fuel oils that are subject to sludge formation. The sludge particles are formed principally by blending and mixing fuel oils of different types, either at the refinery or in the consumer's tank. They may also be formed from reactions due to moisture, heat and oxidation, but the amounts from these factors are small. When the sludge particles are formed, they are quite small and if they remained so, little trouble would occur. Unfortunately, they increase in size as they adhere to each other, becoming so large as to block lines, strainers, pumps and burner nozzles, if drawn into the system.
WHAT DOES A TREATMENT DO?
Many fuel oil treatments on the market today are strictly solvents, which is not the type you want or need. It is extremely difficult to dissolve fuel oil sludge once it has formed, unless excessive quantities of solvent are used, as several times the quantity of sludge present would be necessary. Therefore, a solvent-type treatment is not practical because: The small amounts of treatment used cannot dissolve all the sludge. Not all solvents have the ability to dissolve sludge. A complete treatment should improve atomization and combustion. This cannot be accomplished with small dosages of a solvent-type treatment. As you cannot readily and economically dissolve fuel oil sludge, a treatment must produce the following reactions : Stabilize the fuel oil to minimize sludge formation. Disperse the sludge already present, or formed, as small minute particles. This will permit passage through your system, and out the burner nozzle for combustion. True sludge is easily combustible if particle size remains small. Emulsify and disperse the water so that it too will pass through the system without spitting and sputtering caused by occluded water.
zen is offline   Reply With Quote
Old August 30th, 2005, 11:33 AM     #3 (permalink)
surreal's Avatar
Thanks zen! Now to get some paint that turns red rust to black for the outside of the tanks.
They are old and I think it should be done.. they are really rusty. what do you think?
Old August 30th, 2005, 11:41 AM     #4 (permalink)
zen
zen's Avatar
Sounds like a good idea!
Old August 30th, 2005, 12:05 PM     #5 (permalink)
golfcart's Avatar
I don't know anything about fuel oil, but do the tanks sit outside? If so, I would imagine that black wouldn't be a good choice. We have a ton of propane users around here and I always wondered what would happen if the "pig" was painted black in the middle of summer. Black = Heat = Pressure = Bang. Would be a good one for mythbusters
golfcart is offline   Reply With Quote
Old August 30th, 2005, 12:20 PM     #6 (permalink)
zen
zen's Avatar
Battleship grey!
Old August 30th, 2005, 01:03 PM     #7 (permalink)
Christian-Comp's Avatar
Ours here are white or chrome.
FaD Team 2215 ~ Christianboards.org
"Those who fight the hardest have the most to lose"
Christian-Comp is offline   Reply With Quote
Old August 30th, 2005, 07:39 PM     #8 (permalink)
surreal's Avatar
No they are inside, and have rusted from the basement environment and flooding.
Not paint them black! Paint them with this stuff that turns red rust to black rust which is a not corrosive like red rust is.
Then, I'll probably paint them PINK!!
Old August 30th, 2005, 08:02 PM     #9 (permalink)
It's full of stars ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
paul9 is offline   Reply With Quote
Fill up your gas tanks... Mykex IMO Community 78 September 1st, 2005 09:30 PM
Oil Pressure & Oil Temp Guage Installation usslindstrom IMO Community 2 July 2nd, 2005 04:15 AM
fish in tanks? no thanks shawshank62 IMO Community 23 July 12th, 2004 09:52 AM
Another alternate fuel source: waste cooking oil J-Excel IMO Community 17 January 21st, 2003 03:10 PM
Furry little tanks. desmocat IMO Community 10 September 21st, 2002 07:48 PM
Is It Just Me? (1635)
Review My Build (6)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
windows 7 retail and rtm (4)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
