Results 1 to 6 of 6
Thread: samsung tv help
    Jan 2005
    594
    samsung tv help
    hey all i just bought the official xbox tv, the black samsung, but its in the 26 inch version. i plugged it in, turned it on, hooked up my dvd player, and was amazed at the picture. i can actually see the grains on this tv. for an HDTV, i thought it would be better than that. I dont have an HDTV cables to hook my dvd, but i dont think it will help out
    can someone please help me out in customizing this TV? i dont want to have a picture like this, how can i get it like they have in stores? i bought it for things like watching DVD's and playing my ps2.
    please help me anyone
    i dont want a bad tv. i need to calibrate this
    http://www.sears.com/sr/javasr/produ...0&subcat=HDTVs
    This is the samsung LN-R268W
    thank you
    just passin thru Sweeper's Avatar
    SW, OHIO
    5,850
    Why does it look so good in the store???? Hook up some HD cables up and you'll see. That's a nice TV.
    Also, I saw the exact same TV at a local CompUSA store with the XBOX360 running on it and it was very nice. They were using the RGB cables though. HDTV and standard analog/digital are very different. You'll be suprised at the difference.
    Jan 2005
    594
    do i need hd cables for it to look good? also, my dvd player didng come with any hd cables, so where can i buy hd cables for it? and i need them for the xbox 360 and the ps2. where can i get those?
    Jan 2005
    594
    bump
    ΜΟΛΩΝ ΛΑΒΕ no1_vern's Avatar
    Apr 2002
    Albany, Ga.
    18,482
    This has been talked about in the news section:
    http://www.techimo.com/newsapp/index.pl?photo=15343
    The Xbox360 doesnt do nearly as well as a standard DVD player.
    dulce bellum inexpertis
    ph34r t3h g04t Whir's Avatar
    Kingsford, MI
    29,240
    7
    Fact of the matter is that a DVD is still only 480 lines of resolution. X-Box360 will put out 720 lines with a component video hookup. Cable television looks like crap on HDTVs. The TV has to take that 480 lines up and upconvert it to 768 or whatever your TV happens to be, thus you have image quality loss.
    Yes, there is a difference between component (three color if you want to call it that) and composite. You will get a _much_ cleaner picture from high definition sources through component. If you use composite, you're hamstringing yourself. But it won't matter what you use for normal resolution television and DVDs, it will always look "grainy."
    You should've stuck with the 30".
  1. Samsung 172X va Samsung 710T
    By Dribbles in forum Graphics Cards and Displays
    Last Post: October 23rd, 2004, 12:54 PM
  2. Considering Samsung? Better read this...
    By caddmannq in forum Graphics Cards and Displays
    Last Post: May 21st, 2004, 02:57 PM
  3. Samsung Televisions?
    By THRUSH in forum IMO Community
    Last Post: September 28th, 2003, 10:52 PM
  4. samsung
    By merv62 in forum Graphics Cards and Displays
    Last Post: September 20th, 2003, 07:39 AM
