Results 1 to 16 of 16
    Mar 2002
    Under Your Bed
    8,909
    How do I fix our bath tub hot water valve leak?
    Hey guys!
    One of the first things I have to do when we move into our new place is to stop the bath tub hot water valve leak at the stem. I don't have any pics to show, but basically the water runs out where the stem/hot water knob meet when the water is turned on. I'm sure it's not difficult, but I've never ventured into plumbing territory, so I could use some good advice from you ol' pros.
    How should I go about stopping the leak?
    Thanks!
    Mike the Handyman-to-be
    moo
    moo is offline
    Banned
    May 2004
    Fort Walton Beach
    647
    Quote Originally Posted by Martoch
    here it is..............
    Healdsburg, CA
    13,307
    Shouldn't be any harder than turning off the main water valve, popping off the cover to the knob, removing the screw that holds the assembly together and replacing the appropriate washer. You can take it to the local hardware store for a match.
    IRONyMan RedFury's Avatar
    Jun 2002
    MinneSOta
    5,511
    3
    Rooster beat me to it, but the valve will come out completely. You just have an o-ring that's gone south. Just make sure you shut off the water before you unscrew the thing ( specifically, you most likely will have a cover on the knob you'll need to remove to get at the screw holding the knob on, and then there will be a nut holding the stem assembly to the fixture. Bring it to your local hardware store and they'll hook you right up...
    this post contains small bits of intelligence culminating to the appearance of wisdom.
    Jun 2002
    MinneSOta
    5,511
    3
    Btw, Hot water valves go first, but as long as you are diggin into this, you should just replace the gaskets/stems on both valves as long as you are getting messy anyway. Then you won't have to worry about it.
    Mar 2002
    Under Your Bed
    8,909
    Thanks!
    I already know the answer, but I want to quiz you...um, where do I shut the water off? I know the valves under the sink control the sink water, but what about the tub? Like I said, I'm not asking because I want to know, I want to make sure you know.
    Healdsburg, CA
    13,307
    In my apartment/townhouse, there's a valve outside near the front door that shuts off the main water supply line.
    Ultimate Member jrsweger's Avatar
    Oct 2004
    Upstate NY
    1,645
    There should be a shutoff located where the water enters the house. Mine is located in the basement very close to where the cold water pipe comes through the wall from the street. It might be located somewhere close to your water meter.
    PULL da FINGER
    2,462
    Since you have children,I would suggest testing the unit you are working on and see if it is an antiscalding unit. You can test it by turning on the water and adjusting it as usual for comfortable temperature,then flush the toilet. If the water gets too hot,the unit may not be the antiscalding type.
    Jun 2002
    MinneSOta
    5,511
    3
    Oh but bradoo, do you think Marcough could handle a torch and solder to put a new antiscalding in?
    The whole house shut off valve is located next to the meter. Since you don't have a basement, look by your hotwater heater in the garage...that would be my best guess.
    Mar 2002
    Under Your Bed
    8,909
    Marcough???
    Thanks for your help, guys...I hadn't thought of the antiscalding test yet, so I'll be sure to do that right away.
    Jun 2002
    MinneSOta
    5,511
    3
    We just make sure to take showers when no on has to use the toilet, and if they do...NO FLUSHING! Though, an antiscalding shower would be nice just for the convenience.
    ΜΟΛΩΝ ΛΑΒΕ no1_vern's Avatar
    Apr 2002
    Albany, Ga.
    18,483
    You can prevent scalding by simply setting the hot water tank temperature to about 115-120 degrees(F - incase you were thinking of centigrade). You will get 3 benefits out ot this, it will prevent people from getting scalded, you will lower your power bill, and you will have less leaching of piping stuff(solder from welds, or debris from degraded piping, etc...). Putting an extra hot water tank jacket on the tank wouldnt hurt either, but will cost more than just turning down the temp.
    dulce bellum inexpertis
    Mar 2002
    Under Your Bed
    8,909
    The gas company worker set the temperature at 120F when she tested the hot water tank...the only concern I have with that is the dishwasher/washing machine not doing a good enough job without the recommended 130-140F temp. Otherwise, it can stay at 120F for all I care.
  15. #15
    Communal Member Detritus's Avatar
    Jan 2002
    MI
    25,821
    4
    For the most part, the temp of the incoming water is neutral to the dishwasher, most dishwashers AFAIK heat the water internally. Now the washing machine that is another issue, if you want to wash in hot water, 120'F is just fine. If you get much hotter then that you are actually killing the enzymes in your laundry detergent. Although if you add color safe bleach the hotter the better...
  16. #16
    Mar 2002
    Under Your Bed
    8,909
    Thanks for the info buddy.
  1. Valve why did you do it? -Open letter to Valve
    By LittleKing in forum General Gaming Discussion
    Last Post: November 19th, 2004, 12:25 AM
  2. Home Repair: Elect Hot water heater?
    By jman01pa in forum IMO Community
    Last Post: July 31st, 2004, 12:03 AM
  3. slow draining tub
    By shack in forum IMO Community
    Last Post: October 3rd, 2003, 03:28 PM
  4. Water cooling system HOT
    By sharpsh0t in forum PC Modification
    Last Post: July 24th, 2003, 10:06 PM
  5. Hot & Cold Water
    By ClubMed in forum IMO Community
    Last Post: April 29th, 2002, 06:01 PM
