March 26th, 2002, 05:53 PM
| | The Nebish Jurist
| Removing Crazy Glue from Fingers! Help! Fellow Members & Guests:
Can anyone suggest a sure-fire method to remove crazy glue from fingers? A woman I know very well just telephoned me. She was quite frantic as she was attempting to fix something, and ended up with the glue all over her fingers. She tried finger polish remover but to no avail.
Any ideas?
Thx!
Brangwen  |
March 26th, 2002, 05:59 PM
| | iNsAn3 mEMBER
maybe warm water.. hold hand under warm water.. maybe some rubbing alcohol..
there is actual super glue remover.. but I'll take it she can't get out to get any right now..
In life one must Chill
March 26th, 2002, 06:03 PM
BLOW TORCH.
Most every resource says fingernail polish remover or acetone. Repeated applications with either, rinsing with water between applications. Seems to wear off pretty quickly in any event. If she could get to the polish remover on her own, she isn't too bad off.
WHUT?
March 26th, 2002, 06:23 PM
Maybe it's like in the Simpsons where Bart glues all those novelty pieces, a little human sweat will take it off..  Why didn't she use the super-glue that doesn't "stick" to the skin? |
March 26th, 2002, 06:26 PM
If here fingers are stuck together, then she needs repeated applications of nail-polish remover (acetone based) as suggested, and a little warm water to soak in after. Should then be able to gently peel them apart. If not, she needs to go to an emergency room before it "sets" too much (like within 24 hours, otherwise bonded skin can "grow" together.
If her fingers aren't stuck together, just wave them around to dry before applying acetone. The glue won't help her skin tone  , but it won't do any damage either. They use superglue for wounds now instead of sutures - it's a medical grade glue, but a similiar composition, so the normal stuff won't harm her much (apart from sticking her to things in the first few seconds).
The things you people ask on a tech forum  | |
March 26th, 2002, 06:30 PM
| | The Nebish Jurist
| Mickwish:
I know this "seems" a rather unusual question for a tech forum, but suppose I had written that my friend was gluing a heatsink to some component on a PCB when she got glue on her fingers?
Thx for the replies.
I'll pass them on to her.
Brangwen  |
March 26th, 2002, 06:37 PM
umm you should ask warthog, he has experience! |
March 26th, 2002, 06:43 PM
She should use a bonding thermal paste ( http://www.arcticsilver.com/arctic_silver_adhesives.htm). Not as likely to stick your fingers together. Super glue has no useful thermal conduction properties from what I've heard, so it won't help a heat sink get heat to it. Uselss for heat transfer. I know there are ppl that use superglue to glue on RAM fins to cards, but only a tiny bit on the corners to allow the surfaces still to contact each other.
See, we got a tech reply from it!  | |
March 26th, 2002, 06:51 PM
| | The Nebish Jurist
| Responders:
Thanks for the responses and advice.
The situation is under control.
Brangwen  |
March 26th, 2002, 08:53 PM
| | Misanthropic
LOL
Warthog is a riot, don't want to mention super glue when he's around.  He will start this big story about how he was being a silly pig one night and glued his fingers to...himself..  |
