Results 1 to 9 of 9
    MR Meek and Mild Epidemic's Avatar
    Mar 2002
    almost Virginia
    10,692
    2
    Club Car 36V motor No work after sitting for 5 years.
    What would be the best way to test the motor?
    Wiring is completely shot I have 36 VDC jumpered together and I connected it to the positive and negative leads on the motor and nothing happened.
    I know it worked before the long sit so I guess the windings are ok. What are common things to look for to try and bring the motor back to life.
    there are 4 terminals on the sucker and I am not sure if I have to use any combinations of greater than 2 to make it work?
    ΜΟΛΩΝ ΛΑΒΕ no1_vern's Avatar
    Apr 2002
    Albany, Ga.
    18,484
    What was your power source? 3-12V batteries, or AC/DC converter?
    Do you have an ohmmeter?
    How to Check for a Bad DC Electric Motor | eHow.com
    Extra reading: How does a DC motor work: How DC Electric Motors Work | eHow.com
    Shorts in a DC motor: How Do I Check a DC Motor for Shorts? | eHow.com
    Alsoindustrial motors, so you will need to parse some of the instructions)
    # test insulation resistance of motor wires and windings by using megohmmeter between T1, T2, & T3 leads and ground, then;
    # test “T” leads to motor with ohmmeter for continuity and ohmage of windings between A to B, B to C, A to C; each resistance should be within 1 or 2 ohms of each other; if the ohms readings are significantly different, or, if there is no continuity; go to the motor disconnect box, turn it off, perform the continuity and resistance test on the “T” leads, again; if the readings are good, the problem is in the wires from the motor controller to the disconnect switch;
    # check the three wires by disconnecting all three wires from switch and twist together; go to controller and check for ground with megger, check for continuity between A to C, B to C, A to C; one or more wires will be open or grounded;
    # correct solution is to pull all new wires in from controller to motor disconnect switch, whatever caused the problem may have damaged the other wires, also; replace all wires
    if problem is on motor side of disconnect switch, open motor connection box and disconnect motor;
    # check motor for resistance to ground with megohmmeter, if reading is below 500,000 ohms, motor is grounded and must be replaced;
    # test motor windings for ohms between phases with ohmmeter A to B, B to C, A to C, readings should be within 1 or 2 ohms of each other; if readings indicate open or a significant ohmage difference, replace motor;
    # if motor test readings are good, test the motor leads between the disconnect switch and the motor connection box for continuity and ground resistance, if readings are not good, replace wires;
    dulce bellum inexpertis
    Mar 2002
    almost Virginia
    10,692
    2
    yeah I have an ohm meter.
    I doubt windings so I guess I will go right for checking brushes.
    Pump you sucker! Pump! Chuckiechan's Avatar
    Sacramento, El Norte
    15,323
    I'd take it to an electric motor shop. If the armature is ok, then the reconditioning won't break the bank. (depending on your bank).
    They'll put it on the "growler" - definitely worth watching...
    Obama: The rich have the Federal Reserve and the poor have Harry Reid... LOL. Life really is unfair!
    Mar 2002
    almost Virginia
    10,692
    2
    I am not totally opposed to that but I usually do not like giving money away if emery cloth will fix it.
    It ran until it was parked due to bad batteries. so 5 years of parked does what to a motor?
    Ultimate Member Black*Dragon's Avatar
    Mar 2009
    Occoquan Virginia
    1,319
    Quote Originally Posted by Epidemic View Post
    Can you turn the motor by hand? Usually a motor sitting that long needs to have its bearings oiled and you to turn until it will spin freely.
    Obama Lies
    Grandma Dies
    Mar 2002
    almost Virginia
    10,692
    2
    I am able to push the golf cart freely. My assumption is that yes it spins freely. I charged the batteries and will test tonight to see if I can get it to kick over.
    Why four wires to the motor. Do I need to use more than 2 to kick it over or are they just used for fwd and reverse?
    Mar 2009
    Occoquan Virginia
    1,319
    OK,
    This is not a permanent magnet motor like you have in toy cars. You have a field coil that takes the place of a permanent magnet. 2 wires are for that coil.
    You have the other 2 that apply to the armature through the brushes.
    So without a properly connection to them .....well it does not work.
    OOPS, forgot something.
    NEMA and the NEC requires the motor to be clearly marked as to Voltage, Amps and conections. Look carefully and if you have my luck it is on the side of the motor you cannot see without pulling it.
    Obama Lies
    Grandma Dies
    Mar 2002
    almost Virginia
    10,692
    2
    I will look for a tag. but my guess is it rusted away a generation ago
  1. Rice scientists attach motor to nano car
    By aRIfA4 in forum Tech News Discussion
    Last Post: September 10th, 2008, 12:34 PM
  2. sitting server with adsl
    By ahmad_yehia in forum Networking and Internet
    Last Post: May 6th, 2005, 07:45 AM
  3. SLK 900a not sitting right?
    By Wombat in forum Processors, Memory, and Overclocking
    Last Post: August 20th, 2004, 02:15 AM
  4. Car Model Years
    By xenon200 in forum IMO Community
    Last Post: January 19th, 2003, 06:40 PM
  5. Replies: 24
    Last Post: July 31st, 2002, 09:06 AM
