March 8th, 2004, 06:15 PM #1
screwy mandrake memory problems..
Maybe I'm totally off here.. but isn't linux supposed to be very good at managing memory? Im wondering if I have something setup wrong, because when I startup my system there is about 300MB or 512 RAM free... and after about 30 mins to an hour of casual use (instant messaging, listening to mp3s), the thing is out of memory.
take a look at these pictures for a better idea:
Fresh Startup:
http://www.netsync.net/users/drpmkp/freshboot.jpg
A little later:
http://www.netsync.net/users/drpmkp/30mins.jpg
Also, how come linux does use any of the allocated swap space?
I thought Swap space is where something like disk cache would go?
March 8th, 2004, 06:25 PM #2
Ok, what you are missing here is how linux USES memory.
Linux is very aggressive about placing unused memory into a cache so that it can access it quicker and use it better. If you look at that picture you will see that under 30% of your actual memory is used, the rest is cached for use, still free for programs to use, just ready to be accessed in an efficient manner.
It will not touch your swap partition until you are using a good amount of physical memory, which makes sense as disk access is significantly more costly than main memory access.
That isn't a memory problem, that is efficient use of memory by a kernel
March 8th, 2004, 06:33 PM #3
^^^ what krohnjw said. No point in having perfectly good RAM sat around doing nothing when it can just as well be used for caching data you are quite likely to use again at some point.
Heres a snapshot of the memory usage on my machine (2.6.3 kernel and 768MB of RAM) while its sat at idle with a few apps open, you will notice that I only have 10 meg free...
Swapping to disk is best avoided if you have plenty of free memory to use for caching.Code:Slacker:/etc# free -m total used free shared buffers cached Mem: 756 746 10 0 100 293 -/+ buffers/cache: 352 404 Swap: 486 0 486
The system is not "out of memory", its just attempting to use any free memory it has available to it for something constructive... IMO a sensible piece of memory managment.
Regards
edLast edited by SpookyEddy; March 8th, 2004 at 06:37 PM.
I dreamt that a large eagle circled the room three times and then got into bed with me and took all the blankets.
March 8th, 2004, 06:39 PM #4
k, thx for the explanation. I noticed that when it does get that low it tends to slow down opening programs and such, but still not too terrible.
March 8th, 2004, 06:40 PM #5
It shouldnt slow the opening of programs at all, I would guess this is a spurrious correlation, as you still have over 70% of your system memory free.
March 8th, 2004, 06:42 PM #6
Infact if anything it should speed up some tasks. Just out of interest what kernel version are you running (memory managment, among other things, has seen some fairly radical reworking over the last year or so)?
March 8th, 2004, 06:45 PM #7
um, not sure on the kernell version (nor how to find it out, I'm a noob at linux). I'm running Mandrake 9.2 that I downloaded last december or november
March 8th, 2004, 06:49 PM #8
uname -r
AFAIK that is a late 2.4 kernel, so memory management should be fairly mature and reliable
March 8th, 2004, 06:52 PM #9
It can help built-in graphics, but PS is probably hampered by a lack of features built in, rather than the lack of memory available for graphics. The built-in graphics shares the main memory, but is...
Does any graphics card work on any...
