Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Linux and Unix
Join TechIMO for Free!
Topic: Ok, here's the skinny. For some reason alsa has decided to just load with ALL volumes muted each time I reboot. Now, this isn't a huge problem, as reboots are few and far between, but it is bothersome. This has never ha...
Thread Tools
Currently Active Users: 2685
Discussions: 186,616, Posts: 2,223,741, Members: 229,753
Old November 15th, 2004, 01:14 PM   Digg it!   #1 (permalink)
dword to your moms
krohnjw's Avatar
Send a message via AIM to krohnjw
Alsa causing problems again
Ok, here's the skinny. For some reason alsa has decided to just load with ALL volumes muted each time I reboot. Now, this isn't a huge problem, as reboots are few and far between, but it is bothersome. This has never happened until now, even after the update to 10.1 (this is a mdk box).
However, on one reboot it couldn't load the settings and thus muted everything. Now, no matter what I do, it loads all volumes as default, even though the asound.state file states otherwise. Anyone have any ideas on making also load properly outside of just editing the init script to force it to use a file i specify? (this is about where my patience is right about now with ALSA)
All of the mixer settings are set properly and the driver is fine. Loading the sound module without alsa results in proper volumes, but lack of many audio options I even went ahead and recreated the darn file thinking that for some reason it might not be able to access it. Still nothing will make it load default volumes. This is the same kernel and module it worked fine with for months. Sound all works fine, it is just the default alsa volumes that will not load.
krohnjw is offline   Reply With Quote
Old November 15th, 2004, 06:06 PM     #2 (permalink)
James T's Avatar
In slackware I use alsamixer to set, alsactl store to create the asound.state file and that seems to work fine. I have found that kde sound likes to load it's own volume settings as well and this can override (coming second). I've gone through all the logins and set this setting in kde NOT to load. This was noticeable in my case because the kde defaults were stupid and caused a feedback loop. It might be that your equivalents just turn it quiet?
James T is offline   Reply With Quote
Old November 15th, 2004, 09:23 PM     #3 (permalink)
dword to your moms
krohnjw's Avatar
KDE isn't set to load volumes on login, and I verified earlier that alsactl was saving the file correctly.
It seems to certainly be easier to just modify the init script for the stop and start instructions to save/load a specific file and see how that works.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
XMMS Help Blazer06 Linux and Unix 15 July 5th, 2004 05:55 AM
quick MDK question? washe Linux and Unix 4 December 31st, 2003 02:11 PM
Tell Us How U did that in LINUX netgeek Linux and Unix 5 October 12th, 2003 06:56 AM
audigy2platinum on ANY distro? sixf00t4 Linux and Unix 1 September 3rd, 2003 02:48 AM
Sound and Linux, Im having alot of problems ChoaticWhisper Applications and Operating Systems 5 July 8th, 2002 03:45 PM
If you were watching someone commit.. (8)
Is It Just Me? (16900)
Suit forces eHarmony to offer gay d.. (48)
Super folding (14)
Popular Online Pc Retailers (12)
Folderchat Weekday thread (370)
Official World of Warcraft Thread!! (4505)
Wireless Connectivity (5)
PSU recommendation, think mines is .. (14)
Moving Ghost server to a new ma.. (7)
PC Wont Perform POST (3)
what do you think of SEOBowl co.. (0)
New to the IT field and have a .. (25)
Asus p5wdh 4 gigs Corsaire xms2.. (5)
Problems with WoW wotlk FPS (0)
How to create watermarks in gim.. (0)
Official World of Warcraft Thre.. (4505)
Various items for sale (1)
Woot-off (5)
9800GTX 512meg (8)
