Results 1 to 4 of 4
    Ultimate Member Blitzkreig75's Avatar
    Jul 2005
    Kansas
    1,223
    Question Flash media + fstab in Slackware 11 problem
    I appologise in advance for the small novel, but I wanna be clear and thurough in my description.
    Ok. Distro is Slackware 11, 2.6.17.13 kernel, extramodules installed. All hardware is being detected and working, (with the exceptiuon of my printer, listed, but I think CUPS is not setup all the way).
    The hardware is my primaryrig, (in my sig) , and the card reader is an OTi 7-in-one that connects to the motherboard, (where a USB would got, 9-pin connector).
    The problem:
    I can mount the flash cards and USB drive as root to a /mnt/tmp, and get to the data and do whatever I need to with it on the flash as user once root has mounted the device, but I cannot get fstab setup to be able to mount the 'drives' from the user's desktop.
    I've tried the following settings in /etc/fstab:
    /dev/sd*(sdb-sdf respectively)____/mnt/memory, /mnt/flash, /mnt/usb, mne/OTi_**_CARD_Reader_0123456789abcdef (this last one is how /dev/disk/by-id shows each card slot where ** would be MS, CF, SD, etc...)
    I've tried adding "part1" to both parts of the /dev and /mnt portions, adding just a "1" to both parts, tried replacing "/dev/" with "/mnt" and vice versa, tried adding "grep=100" to the column wehre you have "noauto,user,rw,umask=000", tried setting it to "/dev/usb" in the first column, tried a few other settings (seems I've tried everything) but nothing works. Every time I write to fstab, I gt the pop up window about "new device found", so I know the write is happening, but I've just got something wrong.
    I posted over on Linuxquestions,org, and one user there got me this far, (to be able to get to the data via /mnt/tmp) but he's not familiar with KDE and can't help me any further.
    I've searched the web, googled several different trms, read the Slackware FAQ (it's in my bookmarks now), read a few otehr FAQs and How-To's, but I'm not finding an answer.
    Lastly, I'm thinking it's something simple, since it's working and all, just not the way I'm *thinking* it should.
    Can someone help me get the flash drives to mount for user in the desktop environment?
    EDIT: Oops! My sig don't show my hardware anymore.
    A64 X2 4400+ @ 9x285MHz
    Crucial Ballistix Tracers 2x512 DDR500 @ 233MHz
    DFI DAGF Infinity
    ATI x800XL
    DPT PM1564U3 SCSI controller
    147Gb Fujitsu U3230 10k RPM 80-pin (XP Pro)
    36.4Gb Seagate Cheetah U320 10k RPM 80-pin (Slackware 11)
    (the cardreader) OTi 7-in-one
    The SCSI drives are in a hot-swap bay, not dual-boot
    Check out my music:
    http://www.bandmix.com/blitzkreig75/
    System error 99909: Bang head on keyboard to continue
    Jul 2005
    Kansas
    1,223
    <crickets>
    geez....it's quiet in here.....
    Anyone have an idea?
    Check out my music:
    Senior Member BattleToad's Avatar
    Aug 2004
    Virginia Beach, Va
    603
    can you post your fstab?
    "There are only 10 kinds of people in the world, those that can read binary, and those that cannot."
    Jul 2005
    Kansas
    1,223
    Hmmm...not sure how to do that other than type what I see...
    I'll be on Slack tonight and I'll do just that, but it's not got any entries for the card reader, I've deleted what entries I added because they did not work. But I'll show what it has now....
    BTW, I see it in forums all over, how do I post "text"?
    Check out my music:
  1. Slackware 9.1 install problem
    By GroundZero3 in forum Linux and Unix
    Last Post: April 9th, 2004, 03:31 PM
  2. anyone with flash media reader experience?
    By PSU2Fan in forum Storage Related
    Last Post: January 12th, 2004, 06:12 PM
  3. Samba-fstab issues
    By squeech in forum Linux and Unix
    Last Post: December 23rd, 2003, 11:35 AM
  4. CD-R FSTAB settings
    By Mr Gawler in forum Applications and Operating Systems
    Last Post: July 9th, 2002, 08:10 PM
