Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Linux and Unix
problem with Knoppix
Currently Active Users: 2485
Discussions: 200,959, Posts: 2,379,557, Members: 246,330
Old June 21st, 2008, 09:05 AM   Digg it!   #1 (permalink)
I can't make permanent changes, anythig I do only lasts one session. I am running it off a CD-RW, so it should let me make changes, but my computer is treating the CD-RW as a CD-R. for anyone that wants to try to make a fool of me and say I'm actually using a CD-R, not a CD-RW, I made sure it's a CD-RW, so that isn't the problem. it works fine, until I try to make changes and restart Knoppix later, then it's back to its original settings. anyone know what I'm doing wrong?
Zkunxen is offline   Reply With Quote
Old June 21st, 2008, 11:30 AM     #2 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
You are making a mistake in the way you think the Knoppix CD works. It doesn't matter that it is on a writable CD, nothing you do when using Knoppix changes anything on the CD. It is not meant to do that. Some CD Live distributions of Linux will save some user data in a special file or directory on the hard drive. Those distros would save your changes in a persistant way. Try a Mandriva Live distro. The last one I used a few weeks ago will save your data to a windows partition on your hard drive like that. It will not affect your windows installation apart from placing a few files on the drive and using up a little space.
No man's life, liberty, or property are safe while the legislature is in session. --Mark Twain (1866)
paul9 is offline   Reply With Quote
Old June 21st, 2008, 02:15 PM     #3 (permalink)
You can make Knoppix persistent ... but it involves flash pen drives. See USB KNOPPIX 5.1.1 persistent install from Linux | USB Pen Drive Linux and KNOPPIX Persistent - Saving settings to USB | USB Pen Drive Linux
arochester is offline   Reply With Quote
Soundcard problem on knoppix ltkenbo Linux and Unix 9 February 21st, 2005 04:30 PM
knoppix Tian Linux and Unix 5 August 22nd, 2004 08:40 AM
knoppix help izaic3 Linux and Unix 6 May 8th, 2004 01:13 AM
Knoppix 3.4 is out yclyde Linux and Unix 7 May 4th, 2004 07:01 PM
Trying Knoppix fyxxer32 Applications and Operating Systems 4 March 29th, 2003 09:49 AM
Is It Just Me? (2978)
Making Health Care Worse (181)
Point and Shoot Camera Suggestions. (5)
Print spooler problem (16)
Nvidia GTX 260 problem (1)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
