Hi
You can just reinstall windoze on the same partition(sda0). The others will read unknown in setup.
Windoze will take over grub though and you'll be unable to load grub to start linux. This can be fixed via the ubuntu live cd. For more info check out ubuntu's forums, there's a couple of links with step by steps.
Hope this helps.
