Thread: Noob in need of help!
March 1st, 2010, 03:44 AM #1Junior Member
- Mar 2010
- 1
so i just installed DockbarX and i wanted to install a theme so im following the instructions and it tells me to copy the theme folder into the dockbarX theme folder, but when i try and do that it says i dont have permission to do that. any tips?
March 1st, 2010, 07:13 AM #2Member
- Dec 2007
- Location
- Scotland
- 35
You don't say which distro you are using.
You need to be root or use sudo to open your file manger.
March 13th, 2010, 08:29 AM #3
In Ubuntu
open up the termenal(Applications>Accessories>Term) and type sudo nautilus then copy away.
Other distros log in as root...
P.S. As root you can do anything, so stay out of files if you don't know exactly what you're doing
Please help out a noob
By wblack24 in forum MotherboardsReplies: 6Last Post: July 29th, 2006, 04:56 PM -
Another 'noob' needs help...
By FourKingAce in forum Graphics Cards and DisplaysReplies: 12Last Post: July 17th, 2006, 05:10 PM -
C++ Noob needs help
By redfoxstorm in forum Webmastering and ProgrammingReplies: 46Last Post: March 27th, 2005, 09:22 PM -
noob in need of help.
By triktrak in forum Webmastering and ProgrammingReplies: 5Last Post: January 20th, 2005, 03:23 PM -
Im a noob, but....
By couch potato in forum Webmastering and ProgrammingReplies: 3Last Post: November 4th, 2002, 08:35 PM
Thank you for the swift reply. As far as I can tell there is no NVidia graphics card pre-installed. The system is an every-day-machine intended for Photoshop related work as well as light 3d...
Does any graphics card work on any...
