Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Linux and Unix
Problems with SDL
Currently Active Users: 2661
Discussions: 201,005, Posts: 2,380,078, Members: 246,373
Old June 22nd, 2003, 05:47 AM   Digg it!   #1 (permalink)
Father V2.0
washe's Avatar
Send a message via MSN to washe
Unhappy
Problems with SDL
I'm trying to get Neverwinter Nights to run with the released linux clients but I get this error?
[max@localhost nwn]$ ./nwn
Xlib: extension "XFree86-DRI" missing on display ":0.0".
Fatal signal: Segmentation Fault (SDL Parachute Deployed)
Im running Mandrake 9.1
washe is offline   Reply With Quote
Old June 22nd, 2003, 06:16 AM     #2 (permalink)
Praetorian's Avatar
Edit /etc/X11/XF86Config-4 and uncomment or add these liness.
Load "dri" under Section Module.
and
Section "DRI"
Mode 0666
EndSection
somewhere in there...
Praetorian is offline   Reply With Quote
Old June 22nd, 2003, 06:41 AM     #3 (permalink)
Father V2.0
washe's Avatar
that's actually I got
Section "Module"
Load "dbe" # Double-Buffering Extension
Load "v4l" # Video for Linux
Load "extmod"
Load "type1"
Load "freetype"
Load "glx" # 3D layer
Load "dri" # direct rendering
EndSection
Section "DRI"
Mode 0666
EndSection
after changing to 32 bit depth one error message went away
I have only the following
error
Fatal Signal: Segmentation Fault (SDL Parachute Deployed)
what the hell is that?
Old June 22nd, 2003, 07:31 AM     #4 (permalink)
lynchmob's Avatar
I think that's just a generic message for when SDL has a problem.
Apparently,there's a Linux NWN forum
In this discussion one says to try running it as root,then if it works,find out what NWN needs permissions for.
Not a gamer but I can Google
HTH
lynch
Seldom right,but never in doubt...
lynchmob is offline   Reply With Quote
Old June 23rd, 2003, 02:48 PM     #5 (permalink)
nukes's Avatar
Send a message via AIM to nukes Send a message via Yahoo to nukes
What does glxgears and glxinfo return?
Do they give error messages?
What is your graphics card?
_____
NuKeS
nukes is offline   Reply With Quote
Old June 24th, 2003, 03:38 AM     #6 (permalink)
Father V2.0
washe's Avatar
my card is an ati radeon 9500, i was using some drivers that I read from Rage3d but dindt worked
glxgears
[root@localhost max]# glxgears
1945 frames in 5.0 seconds = 389.000 FPS
2102 frames in 5.0 seconds = 420.400 FPS
2288 frames in 5.0 seconds = 457.600 FPS
2496 frames in 5.0 seconds = 499.200 FPS
2704 frames in 5.0 seconds = 540.800 FPS
glxinfo
display: :0 screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context
client glx vendor string: SGI
client glx version string: 1.2
client glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_ATI_pixel_format_float,
GLX_ATI_render_texture
GLX extensions:
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.3 Mesa 4.0.4
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_lod_bias
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 16 tc 1 16 0 r y . 5 6 5 0 0 16 0 0 0 0 0 0 0 None
0x24 16 tc 1 16 0 r y . 5 6 5 0 0 16 8 16 16 16 0 0 0 None
0x25 16 tc 1 16 0 r y . 5 6 5 8 0 16 8 16 16 16 16 0 0 None
0x26 16 tc 1 16 0 r . . 5 6 5 8 0 16 8 16 16 16 16 0 0 None
0x27 16 dc 1 16 0 r y . 5 6 5 0 0 16 0 0 0 0 0 0 0 None
0x28 16 dc 1 16 0 r y . 5 6 5 0 0 16 8 16 16 16 0 0 0 None
0x29 16 dc 1 16 0 r y . 5 6 5 8 0 16 8 16 16 16 16 0 0 None
0x2a 16 dc 1 16 0 r . . 5 6 5 8 0 16 8 16 16 16 16 0 0 None
Old June 24th, 2003, 04:12 PM     #7 (permalink)
nukes's Avatar
Right, the hardware acceleration hasn't been set up. Go to ati.com and get and install the Linux drivers for that card.
When you installed Mandrake, you clicked the option to install the GLX Acellerated X server didn't you? If you didn't then you will have to reinstall (there are other ways to make the switch, but if you're a new user then it really isn't worth the hassle.)
What version of X is installed? 4.3?
ATI only built drivers for 4.2.1, so I'm not sure how far you'll get.
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
