Go Back   Tech Support Forums - TechIMO.com > PC Hardware and Tech > Linux and Unix
need small help installing gentoo linux (small prob)
Currently Active Users: 1441
Discussions: 200,507, Posts: 2,374,395, Members: 245,831
Old August 18th, 2003, 12:45 PM   Digg it!   #1 (permalink)
Send a message via AIM to SKYLINEGTR33MWJ
i've sucessfully installed other linux systems and i noticed that its all "point and click" now i wanted to go to the next level, the text based installation........ no clicking anywhere, just all good o'l plain text.
i decided to go for gentoo linux, just to give it a try and i noticed that im going to have to install that the "text" way.... i've sucessfully >
1)created partions 2)formated filesystems
3)copied all files needed and extracted them (.tar.bz2)
4)setup the linux "tree" with the "bin mnt etc home usr tmp var" all that stuff everything is FINE!!
exept that i cant manage to edit my FSTAB in "/etc/fstab" using the text based commands, either this or that i dont know the correct ones, something about "nano -w "filename" that dont work!!!
the second problem began while copying and installing my 2.4 gentoo kernel using the command "genkernel" and what not the system stalls and its just currently stuck at "running "make modules"... the cursor is blinking and its been like this for the past HOUR!!! should i restart or whats up? i really want to install this system on this computer (beside me) and i dont want to give up.............
any help anyone? some suggesstions?/
anything is appreciated! thanx!
SKYLINEGTR33MWJ is offline   Reply With Quote
Old August 18th, 2003, 01:08 PM     #2 (permalink)
Mead's Avatar
to edit the file you need to type "nano -w /etc/fstab"
Mead is offline   Reply With Quote
Old August 18th, 2003, 01:17 PM     #3 (permalink)
i notice that it gives me a "cat: cant write, badpipe error" something like this when i "emerged" some of the files......
and i try the nano -w "/etc/fstab" and it tells me "illegal operation" something like thisi dont know why......
and right now im in the final stage of installation and i still cant get that "lilo" installed becuz of the same reason it tells me "illegal operation"
Old August 18th, 2003, 02:48 PM     #4 (permalink)
nukes's Avatar
Send a message via AIM to nukes Send a message via Yahoo to nukes
Maybe you should start again. I've never had any problems installing Gentoo.
You're still running off the LiveCD right? Not the installed Linux system?
What stage did you start at? 1, 2 or 3?
_____
NuKeS
nukes is offline   Reply With Quote
Old August 19th, 2003, 10:02 AM     #5 (permalink)
i started off stage3 for pentium 3 pc's
i really want this gentoo linux on my system but i dontk now how.. i did all the necessary things i had to do but i get these "cat write error "badpipe" something like that but the files to get copied from place to place i dont know.
Is It Just Me? (1635)
Review My Build (5)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
