Voltage & Power Supply question
Currently Active Users: 1468
Discussions: 200,931, Posts: 2,379,161, Members: 246,297
Old April 3rd, 2004, 09:40 PM   Digg it!   #1 (permalink)
Question
Hi all!
I bought a new laptop a month ago, it came with a power supply that reads "Input: 110-240V~ 1.6-0.9A 50-60Hz " on it. However, due to a sudden event, I had to move from North America (uses 110V) to a place in Asia (uses 220V) for awhile.
Now, do I need to get a "voltage convertor" or something similar? Or that power supply which came with the laptop will change the voltage for me automatically since it wrote "Input: 110-240v" on itself?
Thank you in advance.
ps. I am new member, I hope I didn't voilate any rules yet. hehe
Armani
Armani is offline   Reply With Quote
Old April 3rd, 2004, 09:45 PM     #2 (permalink)
Messiah89's Avatar
Isn't there a little red switch on the back that you can move over and it'll switch from 115v to 240v?
Hmm, maybe not if it's a laptop.
AMD Athlon 64 3000+ @ 2GHz
Gigabyte GA-K8NSC-939
Corsair 1GB PC3200 DDR RAM
Maxtor 120GB 7200RPM Hard Drive
XFX GeForce 6600GT 128MB AGP
Messiah89 is offline   Reply With Quote
Old April 4th, 2004, 11:26 AM     #3 (permalink)
Hmm, I don't see a switch or anything like that, it just read "Input: 110-240V~ 1.6-0.9A 50-60Hz" on the label of the power supply and that's all the info I've got.
Old April 4th, 2004, 12:52 PM     #4 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
your laptop power supply (like most) is designed to accept a wide range of power incl europe & asia standards.
all you need is a simple plug converter so that you can 'convert' the 'US style connector' to match whichever country you are in.
Old April 4th, 2004, 12:54 PM     #5 (permalink)
The FNG
rrcn's Avatar
Well if you still have the manual for the laptop, you can always check it just to make sure.
rrcn is offline   Reply With Quote
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
