Applying Thermal Compound
Currently Active Users: 2288
Discussions: 200,993, Posts: 2,379,919, Members: 246,362
Old April 4th, 2004, 01:16 PM   Digg it!   #1 (permalink)
Anyone know a good guide for applying thermal compound ( grease ) to a laptop cpu?? i found quite a few guides for desktops but not many for laptops on google...
Also would aplying thermal compound void my 2 yr comp usa warranty??? ( since i would have to open my laptop )
thanks
jai6638 is offline   Reply With Quote
Old April 4th, 2004, 02:10 PM     #2 (permalink)
Not Really a Member
are you also replacing the heatsink?
I would have to lean towards yes on the void of warranty seeing as laptops are extra sensitive.
Typically they're designed specifically for the components that are currently in there.
Much change and it could have detrimental effects.
vass0922 is online now   Reply With Quote
Old April 5th, 2004, 02:47 PM     #3 (permalink)
well i am actually a noob.. not sure.... to apply thermal paste on my cpu would i have to remove my heatsink and put it back again????????
if it makes any difference , i have a toshiba satellite 5205-s703
Old April 5th, 2004, 03:20 PM     #4 (permalink)
Anime Otaku
RobRich's Avatar
You will likely invalidate your warranty the second you crack open the casing on your notebook.
As to thermal paste, most notebooks have a thermal interface pad instead of thermal paste. This pad is a certain thickness that can not be replaced by thermal paste depending on the length and flexibiliy of the heatsink's retaining mechanism. You may end up with an air gap if you do not use the factory thermal pad.
If you are definitely sure on the thickness, thermal paste can applied after you remove the thermal pad with a credit card. Clean the heatsink base with alcohol, then apply a thin layer of paste.
Robert Richmond
Robert Richmond | TechIMO Community Relations Director
Infinite perceptions. One reality.
FanFiction.Net - Unleash your imagination.
RobRich is online now   Reply With Quote
Is It Just Me? (3086)
Foxconn Blackops x48 MoBo (5)
Health Care Rationing (15)
Delete an OS (17)
Nvidia GTX 260 problem (12)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
