Hi all,
I just found out that this was an available option for my 5100, but it's a little confusing. What mini pci cards would you all suggest (I'm assuming they work on most wireless router/access points).
Also, in the Dell literature, it states that, by law, only a qualified tech can install a 5 mhz card, but you can install your own 2.4 mini pci card. What's up with that?
Thanks in advance, and GO BOLTS!
