Inspiron 5100 wireless mini-pci card; 2.4 or 5 mhz differences?
Currently Active Users: 2366
Discussions: 200,940, Posts: 2,379,263, Members: 246,304
Old April 14th, 2004, 05:02 PM   Digg it!   #1 (permalink)
LeftCoast's Avatar
Hi all,
I just found out that this was an available option for my 5100, but it's a little confusing. What mini pci cards would you all suggest (I'm assuming they work on most wireless router/access points).
Also, in the Dell literature, it states that, by law, only a qualified tech can install a 5 mhz card, but you can install your own 2.4 mini pci card. What's up with that?
Thanks in advance, and GO BOLTS!
Millions long for immortality who don't know what to do with themselves on a rainy Sunday afternoon.
Susan Ertz
LeftCoast is offline   Reply With Quote
Old April 14th, 2004, 05:08 PM     #2 (permalink)
Perfetc Member
VHockey86's Avatar
2.4ghz is the frequency wireless B and G are at, these are by far the most common.
5ghz is A, about the half the range and same speed as G but not compatible with B or G networks.
I would go with the 2.4ghz
VHockey86 is offline   Reply With Quote
Old April 14th, 2004, 05:15 PM     #3 (permalink)
Perfetc Member
VHockey86's Avatar
http://www.linksys.com/edu/wirelessstandards.asp
Old April 14th, 2004, 05:50 PM     #4 (permalink)
LeftCoast's Avatar
Nice link. Thx.
I was thinking you could get a dual mini pci, to cover all the bases, but more than the G is prob overkill fo me anyway.
Is It Just Me? (2910)
Wireless Televisions. (8)
Regular Build (6)
Obama the Muslim (14)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
screen resolution vs monitor size (0)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
