Here is one idea: open the laptop so you can get to the place where the plug is mounted. Solder a couple wires on where the plug is attached. Run the wires to the outside of the laptop. Now you should have a set of power wires coming out of the laptop. Connect a matching set of male/female plugs onto the ends of the wires and your power supply.
