S Cable - Connecting laptop to tv monitor
Currently Active Users: 1885
Discussions: 200,921, Posts: 2,379,089, Members: 246,289
Old September 1st, 2004, 09:48 PM     #11 (permalink)
Exclamation
S-Video Cable
I have a Toshiba Satellite laptop and the cable that came with it has 3 ends that connect to the tv. However, none of them fit the S-Video slot. They are ordinary video and sound plugs. When I try to connect my laptop to my tv I hear the sound come from my tv's speakers but there is no video. Is this because my cable is not inserted in the S-Video slot? Can someone please help me?
currykarpal is offline   Reply With Quote
Old September 2nd, 2004, 09:05 AM     #12 (permalink)
Currykerpal u sound as if u need a cable called svideo-to-3rac. I assume u dont have this cable as one end would be a svideo end and plug into the back of ur laptop. If ur tv has a svideo port, use a svideo-to-svideo cable for better picture quality. The cable u have sounds like a 3RAC-to-3RAC( 3 coloured plugs on each end)? I would be surprised if this second cable came with ur laptop, as most laptops cannot use such a cable.
Again look at the sites ive posted previously. There is a step by step guide there somewhere if i remember correctly. Check ur cable and good luck.
jimbop is offline   Reply With Quote
Old September 2nd, 2004, 09:09 AM     #13 (permalink)
muarrif's Avatar
Send a message via MSN to muarrif Send a message via Yahoo to muarrif Send a message via Skype™ to muarrif
Svideo
Most new TVs have Svideo input builtin
I am normally able to connect my computer and display on TV
Normally on LapTops you need to press Alt+F7 to toggel between outputs
muarrif is offline   Reply With Quote
Old September 2nd, 2004, 10:30 AM     #14 (permalink)
mingyu01's Avatar
Send a message via AIM to mingyu01
Its usually Fn key next to left ctrl key not Alt key
mingyu01 is offline   Reply With Quote
Old September 2nd, 2004, 10:35 AM     #15 (permalink)
muarrif's Avatar
OOOOPS
Thank you for the correction
Yes your are quite right
Old September 2nd, 2004, 02:23 PM     #16 (permalink)
Exclamation
S-Video
The cable that I have has 1 plug on one side and 3 plugs on the other side. The 1 plugged side goes into my laptop and the other side into my tv. My laptop doesn't have an S-Video output. What am I supposed to do? Is S-Video to RCA the cable that I'm looking for?
When I use the cable that I have right now, I get sound on the TV but instead of video I see waves on the screen. What could be the problem?
Old September 2nd, 2004, 09:02 PM     #17 (permalink)
What type of laptop do you have? What's the specs (esp graghics card) and ur Operating System? Do u have any idea what the cable u have is called (mentioned in ur comp manual?), as if ur sure ur laptop doesn't have a svideo output, then things get abit trickier!!
What colours r at both ends of the cable (red & white for sound, yellow for video generally)
Old September 2nd, 2004, 10:13 PM     #18 (permalink)
Here is what I have..
Laptop: Toshiba Satellite 5200
Card: NVIDIA GeForce FX Go5600
Cable: 1st end.. black plugs, 2nd end.. red, white, yellow plugs
I talked to Toshiba support centre and people from FutureShop store.. I have the right cable. They believe the problem could be caused by settings or software/hardware problem. They tell me it could take them a month to diagnose the problem. So I'm trying to see if I can fix the problem myself (as long as it's not a hardware problem) Can anyone help me with the software or the settings?
Old September 3rd, 2004, 02:20 PM     #19 (permalink)
try this website http://www.nvidia.com/object/feature_nview.html see if this helps u at all. Also make sure ur drivers r updated. What OS r u using? XP, 2000, ME?
Old September 4th, 2004, 04:06 PM     #20 (permalink)
I downloaded the latest forceware and tried everything on my configuration settings. I am still seeing waves on my screen. I don't know what to to...
External monitor for laptop Marcus147 Graphics Cards and Displays 5 September 13th, 2004 06:43 AM
KVM Switch question CyberGhost General Tech Discussion 8 June 16th, 2004 03:48 PM
IP Address imt4000 Networking and Internet 26 June 16th, 2003 04:56 AM
Win2K/ XP Network Question for Newbie nodnerb2 Networking and Internet 8 February 22nd, 2003 12:50 PM
This maybe a stupid question MyBestInternet Technical Support 18 August 1st, 2002 12:17 AM
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
Is It Just Me? (2854)
Obama the Muslim (13)
radeon x850xt platinum & shader 3 (1)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
