Join TechIMO for Free!
Topic: Hi, I purchased an S Cable and tried to connect this cable from my laptop to the tv, however, I am not sure what kind of settings that I would need to do in order to transfer the DVD picture from my laptop to the tv. A...
Thread Tools
Currently Active Users: 2277
Discussions: 186,226, Posts: 2,222,770, Members: 229,784
Old September 4th, 2004, 09:59 PM     #21 (permalink)
The FNG
rrcn's Avatar
currykarpal, what kind of "black plug" is it? S-video? There are all sorts of black plugs it can be. Can you take a picture of the plug and the port it plugs into?
rrcn is offline   Reply With Quote
Old January 2nd, 2005, 11:19 AM     #22 (permalink)
I was using my laptop regullarly to watch movies,but some days ago laptop was totally hanged and it was infected with virus . I have run the recovery CD and reinstalled my laptop,but now i cant connect my laptop to TV .While connecting I can only see hazy screen on tv,but on laptop I am enable to see movie ,can u please help me out of these.
Achurens is offline   Reply With Quote
Old December 4th, 2006, 06:26 PM     #23 (permalink)
Thumbs up
Connecting laptop to TV
Hi Everybody,
Googling and searching the discussion boards on connecting my laptop(Compaq Presario 2182US) to Apex Tv with S Video to RCA Adapter, I was finally able to get the display of my laptop to TV. I have scratched my head for hours to get this.Everything I did seemed to be right except that it was not working. Here is what happened.
After making the connections (S video of laptop to RCA of TV with an "S video to RCA Adapter") I hit Fn + F5 on laptop, my laptop screen would flicker for a second and I see nothing on TV. Later I connected the RCA cable to video port of my VCR I was able to switch the display from my laptop as I could see a blank screen on laptop when I hit Fn + F5. Then I unplugged the cable from VCR & connected the RCA cable to Video port of TV and was able to get the display. I still have to do this every time I want to connect my laptop to TV.
I do not know exact technical deal behind this but my guess is my TV is not giving some hand shake signals to laptop which recognizes it as an external display. I came to this conclusion as the same laptop works fine without changing any settings when i connected to my friends sony tv.
Hope this helps & saves some time for others who are facing similar kind of problems.
Thanks for all your help
rvbabu is offline   Reply With Quote
Old December 5th, 2006, 06:46 AM     #24 (permalink)
hi, rvbabu
Not sure what the problem is as you are getting a display? it sounds as if you haven't checked the cycle present in the display switching,
http://h10025.www1.hp.com/ewfrf/wc/d...product=374007
but i tend to sort everything out in display properties first.
Also, there is no 'handshake' present with Svideo (unlike USB for example) as the picture info only travels one way. It is more a case of setting the PC up to send and then having the TV on the correct channel.
Oh and Black and white images are to do with PAL (europe) and NTSC (USA) design - there is lots of info kicking about on this subject. http://www.videohelp.com is always a first port of call.
Any more Qus i'll see what i can do.
Jimbop
jimbop is offline   Reply With Quote
Old December 20th, 2006, 07:53 PM     #25 (permalink)
Monitor is either black or white/and or jumping
Thanks you all in advance for any help you may provide.
I have two laptops
one is a hp dv 5000 and the 2nd is hp dv1000, both have expansion ports for a all in one media cable.....has s-video, audio cables...etc
With that in mind, I have a fairly new TV, A samsung, that has a s-video spot. When I hook up my laptop I not only get a black and white screen, but the picture jumps almost like that tracking is off (vcr tapes). When I hook up the 2nd laptop using the same wires, I get a black and white screen. Among HP support telling me my laptop doesnt support the tv which is a year older than my laptop, and spending 60 bucks for support that didnt help, I am finally at my wits end.
I have tried adjusting the display properties, and as far as I know the drivers have been updated.....or my moniter manufacturer is not listed.
IOf anyone knows how to rectify this issue, i would be a happy man.
thanks again
crackzilla79 is offline   Reply With Quote
Old December 21st, 2006, 05:49 PM     #26 (permalink)
Human voltmeter
DanU's Avatar
S-Video is composed of two signals, a chrominance (color) signal and a luminance (brightness) signal. If the chrominance signal is missing, you will get a "black and white" picture.
Check your laptop's video out settings and make sure you are outputting S-Video and not composite video.
You may also have a bad cable.
Old December 21st, 2006, 09:52 PM     #27 (permalink)
where do i check the video out settings, and how do i check to see if its outputting s-video or composite video. the media in one cable is pretty new, as well as the s-video cable. So I just need to know how to set it up correctly.
thanks
Old January 6th, 2007, 10:45 AM     #28 (permalink)
I have the same exact problem! Did you find a solution? I have checked all display settings. I used a Dell to connect...and that worked! Obviously it's an HP issue...not an s-video or Samsung issue!
myanny is offline   Reply With Quote
Old January 9th, 2007, 11:35 AM     #29 (permalink)
I got it.
After trying many of your suggestions, and by troubleshooting different things, i finally got it to work on both my laptops for my TV......anyone who has this problem of a black and white screen or a jumping screen should contact me at crackzilla79@msn.com.
Unfortunately, I can't remember how to do this exactly since it has been a week or so, but anyone interested in that info, I will do my best to make sure you have the results i got, as well as the procedure in how to fix this problem or shall i say setting in the display prooperties. Manny, just give me a shout and I will email you and all who are needing this info.
Thanks again for all you help.
Old January 9th, 2007, 06:58 PM     #30 (permalink)
Human voltmeter
DanU's Avatar
Glad to hear you got it fixed. For the benefit of others, could you post a quick explanation of what you did? Was it in your display properties?
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
External monitor for laptop Marcus147 Graphics Cards and Displays 5 September 13th, 2004 06:43 AM
KVM Switch question CyberGhost General Tech Discussion 8 June 16th, 2004 03:48 PM
IP Address imt4000 Networking and Internet 26 June 16th, 2003 04:56 AM
Win2K/ XP Network Question for Newbie nodnerb2 Networking and Internet 8 February 22nd, 2003 12:50 PM
This maybe a stupid question MyBestInternet Technical Support 18 August 1st, 2002 12:17 AM
Is It Just Me? (16969)
hi (7)
So GLAD winter's finally here !! (21)
FolderChat: Weekend time again! (284)
Folderchat Weekday thread (373)
Super folding (18)
Popular Online Pc Retailers (12)
AM2+/AM3 (9)
PSU recommendation, think mines is .. (14)
FS: New Benny Hill Megaset DVD .. (0)
How to position dos window (0)
Super folding (18)
RETTEN.EXE missing (1)
HDMI Cables (6)
Is it worth the upgrade? (2)
Need advice from you experts... (2)
Help me to find Equivalent Powe.. (156)
Calculating KVA/MAX (7)
Why do you use "Vista".. (29)
Seald copy of windows 95 for sa.. (0)
Various items for sale (1)
