November 6th, 2007, 12:30 PM
#41 (permalink)
| | Human voltmeter
Did you try the suggestions in this thread? Is the video format set correctly to PAL or NTSC? Is the signal output set correctly to S-video? |
January 28th, 2008, 12:17 PM
#42 (permalink)
All u have 2 do is push down fn and f5 not f4 then these little blocks will come up keep fn pressed and then push f5 again and the 2nd block will be highlited and this block means that u can c the picture in both the tv and comp. moniter and if u push f5 (still keeping fn pressed) again then it will switch as to where u can only c the picture on ur tv screen
i can't figure this out hto i only get soung fro the comp. not the tv |
February 12th, 2008, 11:38 AM
#43 (permalink)
have you found out the solution.... ??? i have the same problem,,, if you know how to fix,,, please email me...benoitrich@hotmail.com,,,, and even if you haven't ,, email me,,, i will let you know when i find out info...... rick |
February 13th, 2008, 02:36 AM
#44 (permalink)
All you need do is hook up ur laptop and your TV using S-VIDEO cable. THen press F5, and choose the second block.
The picture quality is pretty bad. My laptop has VGA port, and my TV has DVI. I am wondering if I use VGA to DVI cable, will the video quality be better? |
February 13th, 2008, 06:54 PM
#45 (permalink)
| | Human voltmeter
That depends on the TV. Your TV may only support digital DVI input. VGA is a purely analog signal. Check with your TV manual/specs to see if it will accept an analog VGA/DVI input. |
May 25th, 2008, 02:19 PM
#46 (permalink)
| Connecting 7 PIn Svideo out to 4 PIn Svideo In
Hello,
I have a Dell Inspiron 6000 and it has an Svideo out that has 7 pins. My TV is a Toshiba and it has Svdieo in that has 4 pins. Can I use a regular 4 pin Svideo cable in the 7 pin out or is there some special adapter I need? I have tried hooking it up and I get no signal. Have tried playing around wih settings in the Display but nothing seems to be working. |
June 19th, 2008, 07:33 PM
#47 (permalink)
| S-cables
I connected everything fine between my laptop and TV monitor -- its worked for the past two years. All of a sudden the picture has no colour. I can't figure out why unless I need a new S-cable but shouldn't the cable last more then three years???
Confused! |
August 27th, 2008, 09:09 PM
#48 (permalink)
Need some help. Trying to hook my Toshiba Laptop to my Olivea 32 flatscreen. Works easy on my Imacs but not on my laptop. Both are new and less than 8 months old. VGA input is what I used before. I am considering using s-video cable. I kind of lost right not. Can anyone assist? |
September 3rd, 2008, 05:45 PM
#49 (permalink)
| Find Easy the rigrt Cable
If anyone have same problem with connecting laptop/pc to tv try this website: PLUG PC OR LAPTOP TO TV - The best way to find right cable. |
