S Cable - Connecting laptop to tv monitor
Currently Active Users: 1813
Discussions: 200,933, Posts: 2,379,198, Members: 246,298
Old December 22nd, 2008, 02:15 AM     #51 (permalink)
Question
S Video Cable
I have a question. I have a box from my cable company that has a spot on it labled S Video Cable but yet it doesn't have the connector to plug it in. It's like they took it out or something. Can I just buy a connector with the S Video Cable and hook it up or is this something the cable company would have to do? Thanks.
Madonna is offline   Reply With Quote
Old December 30th, 2008, 08:05 AM     #52 (permalink)
Hi well after going over this thread for the last few days i seem to be no nearer the end! I have a RCA connection on my laptop philips freevents x56 which i have a converter to an s-video attachment. I connect the cables together put it in the side of my television to the s-video connection but i dont get a picture. I know the s-video cable works as i hooked the bt vision box up with it to the same connections and it worked fine. So i guess its something im not doin right with the laptop. The television just says no signal! i go to the graphics media icon in the bottom right and choose output device and choose monitor but it doesnt do anything?
Really need your help guys and girls
most appreciated
David
davidavid is offline   Reply With Quote
Old January 1st, 2009, 01:54 PM     #53 (permalink)
Hi David
What your are looking to do is switch on your external video output - the best way to do this is right click anywhere on your desktop and select 'properties' - the wording varies depending on whether you're XP or Vista +/- your graphics card type. Then find say 'settings' then 'advanced' then 'monitors', and activate your RCA output.
A can't explain more till we know your OS (vista /XP etc and your TV make and model)
Happy new year!
jimbop is offline   Reply With Quote
Old January 2nd, 2009, 03:56 PM     #54 (permalink)
Smile
Solution to your connection problem
The use of a VGA connection with component connections will not work as you have found out. What you need is a VGA to RCA. (Red, White, Yellow) This type of adapter is available at most electronic parts stores. (Radio Shack, ect. or you call get them at sites such as Ebay. Very easy problem to fix. Cost is $3.00 to $20.00 U.S. Ebay is the cheapest, $3.00 U.S. with free shipping.
Originally Posted by sanjeewa19 View Post
I have the following configuration
Laptop Toshiba Satellite A200 (Win XP)
- S-Video(4 Pin) Output YES
- VGA Output YES
TV Samsung 21" Normal TV
-S-Video Input NO
-RCA Component Input (3 Red Green Blue Holes) YES
I have got a Cable VGA to Component. (One side VGA Male port other side 3 Male jacks Red Green Blue). I connected VGA side to my laptop and Component side to Component in jacks on my TV. I have done Fn + F5. My Laptop screens goes off but nothing displays on TV.
I am wondering whether VGA to Component will work without any adapter? What would be the solution for me on above configuration.
Thanks everyone in advance.
sing4me_kj is offline   Reply With Quote
Old January 2nd, 2009, 10:11 PM     #55 (permalink)
qrs321's Avatar
Send a message via AIM to qrs321
hahaha, it seems like you guys are helping each-other out, but you do know that this thread started in 2004 right?
qrs321 is offline   Reply With Quote
Old January 4th, 2009, 01:11 PM     #56 (permalink)
I thought that was the whole point in helping each other out so not too sure whats so funny about it? and what the start date has do with it i dont get either whats better starting 100 of the same threads or reopening one? thanks for the useful reply
Old January 4th, 2009, 11:41 PM     #57 (permalink)
removed by user
crackzilla79 is offline   Reply With Quote
Old January 10th, 2009, 01:30 PM     #58 (permalink)
Hi its me again, well i ditched the s video idea and bought a vga to vca cable in the hope that it would work however i got my cable today and tried it out. I matched the colours on the cable ends to the tv ones but still nothin so im beginning to think theres something not quite right here. The laptop definately recognises that another monitor is plugged in a i get the graphics media device come up with the option showing the monitor. I have made sure the refresh rate on both are at 60mhz and both 800X600 (or what ever it is) but the tele still says no signal! its really starting to annoy me now, lol. Any suggestions or things that i may have missed?
Thanks for the help
Tv is a phillips 42 pfl lcd laptop is phillips freevents notebook
Old January 14th, 2009, 10:03 PM     #59 (permalink)
Hi guys!
I've found this thread like most, while searching for reasons as to why my s-video connection no longer works. I haven't been able to find anything in previous posts that seem to help with my problem. (Pardon me if my solution is repeated in an earlier post, i missed it, sorry!)
I have a HP Pavilion tx1000 with NVIDEA GeForce Go 6150 video card. I connect the s-video cable (it's a 4-pin cable into a 7-pin connection, lemme know if that could be a problem) to the computer then to the adapter, then to the yellow video RCA jack and then to the TV (the tv changes, Samsung, Magnavox, etc) and I can extend my desktop to the television. Until today when I did the same thing I always do and nothing. It acts as if there is no display and I cannot figure for the life of me what has changed.
I've used different video jacks and I've tested the s-video cable my using it to connect my DVD player and it all works. So something has changed on my laptop and I don't know what it is. Please help!
Also, my OS is Vista and I have recently updated the NVIDIA drivers.
You can either reply on here or email me at moran.146@osu.edu
moranga is offline   Reply With Quote
Old January 23rd, 2009, 05:20 PM     #60 (permalink)
Vga to Composit Video.
I got this cable that is suppose to be able to allow me to view my laptop on my tv. I messed about with the video settings and enabled the extended screen. I still nothing but a blue screen on my tv. any suggestions?
Neojersey is offline   Reply With Quote
External monitor for laptop Marcus147 Graphics Cards and Displays 5 September 13th, 2004 06:43 AM
KVM Switch question CyberGhost General Tech Discussion 8 June 16th, 2004 03:48 PM
IP Address imt4000 Networking and Internet 26 June 16th, 2003 04:56 AM
Win2K/ XP Network Question for Newbie nodnerb2 Networking and Internet 8 February 22nd, 2003 12:50 PM
This maybe a stupid question MyBestInternet Technical Support 18 August 1st, 2002 12:17 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Is It Just Me? (2889)
Wireless Televisions. (5)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
