hp compaq nc6000 problems
Currently Active Users: 1440
Discussions: 200,905, Posts: 2,378,901, Members: 246,275
Old March 17th, 2009, 03:09 PM     #151 (permalink)
I filed my tip down with a dremel tool until it looked like a pin.
And I used no solder. When you touch the pin, (not at the base, up on the leg) you can see the solder soften almost instantly. That is all you need to do. Touch each pin, as you go around the chip. I did about five, then let it sit for a few seconds to cool off. Too much heat and you will have other problems...
I don't think you could even get solder down on the chip legs as they are so small... If you try to add some, you will probably end up connecting two legs together... Which would be no good, and cause weird things to happen...
Good luck.
FreeEnterprise is offline   Reply With Quote
Old March 17th, 2009, 11:21 PM     #152 (permalink)
Thanks so much for your reply. I have already done the soldering, with a 0.2mm soldering tip I bought. Luckily I think I did pretty much as you said. Not sure exactly what you mean by "not at the base, up on the leg", as the tip I had was about the same size as the tiny bead of solder on each connection.
I saw a whisp of smoke on some occasions, but even with a 10x magnification glass I bought I couldn't see enough detail to determine the solder flowed or not. I just applied about 1-sec heat each joint.
The result seemed good at first but now I am not sure. Basically I can boot consistently now, which I could not before, but I am finding it not reading the hard disk correctly. I thought the HDD must be the problem, so I tried another one from another Toshiba laptop I have and it had same problem - gets a disk read error during the BIOS HDD self test. It generally runs Windows ok, but occasionally will run very slowly, and then BSOD after the HDD thrashed away for a few minutes.
Pretty sure I need to have another crack at that chip. I know I have made some difference since before I started the computer wouldn't always respond to the power button. And even when it did, the presence of a HDD would make it hang even before the BIOS could be launched.
bobban is offline   Reply With Quote
Old March 21st, 2009, 05:22 AM     #153 (permalink)
Question
replace HDD with flash
I have hard disc problems with my NC6000, ticking, and BSOD after an unpredictable amount of time: has anyone succeeded in installing an ide/compact flash.?
Which driver files would it be prudent to rescue from my dodgy hard disc?
I have 1.5gb ram installed, and would like to run XP in ram using a smallish flash card as a boot up rom, and using a RW cd or external USB stick to store any odd files. Is this possible?
regards Rissole
Rissole is offline   Reply With Quote
Old March 21st, 2009, 03:28 PM     #154 (permalink)
blue light
Hi!
The blue light doesn't work on mine.
The wireles is ok, but when i press the button nothing happens.
could u help?
thanks
Matti is offline   Reply With Quote
Old April 8th, 2009, 04:56 AM     #155 (permalink)
Matti you may just not have a wireless card in your laptop turn it up side down and just to the bottom left of the heat sink fan theres a little compartment open that with a screw driver. There should be a green card if it is empty you could either buy one or get a wifi card but you would need a wifi input if you were to buy a wireless card for inside the hp compaq nc6000 i would recomend one from ebay because they are very cheap i did a fast search for you and found these at the top of the list
cgi.ebay.co.uk/MINI-PCI-E-WIRELESS%2FWIFI-CARD-4-HP%2FCOMPAQ%2FDELL-&AIRPORT
So hope the Auto-IT team has helped .
Auto-IT is offline   Reply With Quote
Old April 9th, 2009, 02:49 PM     #156 (permalink)
Thanks,
But, it must be a wireless card in it, 'couse it works. Found the network automatically. Just I can not switch it on or off. When you switch the computer on the light is flashing.
Anyway it's a real light-minded problem just for fun... I like this machine
Thx, for the answer again
Old April 15th, 2009, 10:16 PM     #157 (permalink)
help ??
Hi,
I am intimately familiar with the classic NC6000 mobo problem, I have replaced several myself.
This is a different problem: with the AC adapter plugged in, the display becomes pixelated and garbled (after 1-2 minutes, then becomes unuseable due to the frozen display). Unplug the AC adapter and the problem goes away (immediately) and the laptop functions perfectly on battery power. Where do I begin to troubleshoot this? Is this a known problem?
Thanks.
splicesite is offline   Reply With Quote
Old May 1st, 2009, 08:18 AM     #158 (permalink)
Hello friends,
i am having problem with my nc6000. it just hang suddenly. No specific time to hang it just hang suddenly.
sreza26 is offline   Reply With Quote
Old May 8th, 2009, 04:11 PM     #159 (permalink)
Talking
Blue light
Originally Posted by Matti View Post
Hi!
could u help?
thanks
So this happnd to me as well on my nc6000. I took the laptop apart and the ribbon cable that goes from the motherboard to the lights on the front of the laptop had come partially disconnected. I reseated the cable and it works fine now. Hope this helps you.
gtmason is offline   Reply With Quote
Old May 22nd, 2009, 05:26 AM     #160 (permalink)
Good luck.
Hey I followed your advice. I ended up re-flowing the solder on the front and right set of legs, and the others looked in good shape. Rebuilt the laptop and it booted and has been working for a few hours.
Here is a flikr album of some shots I took with a 200x microscope with some before and afters, and the iron tip I used;
nc6000 mb solder job - a set on Flickr
This was after reflowing with a 12W iron with a a filed down tip;
This was the tip I used;
That's a match head on the right ;-)
tolland is offline   Reply With Quote
S Cable - Connecting laptop to tv monitor coopersveronica Mobile Computing 71 October 26th, 2009 08:55 PM
...compaqs, hps, gateways, etc engineuity General Tech Discussion 22 May 7th, 2004 12:14 AM
Compaq power supplies Cyberlore Technical Support 19 April 26th, 2003 11:14 PM
Laptops...cheap AND powerful??? Possible? Tekk General Tech Discussion 4 November 28th, 2001 06:58 AM
Is It Just Me? (2809)
California Passes Anti-Flat-HDTV Le.. (38)
Fox uses old news clips to inflate .. (33)
HIS HD5770 graphic card question (14)
Foreign voltage (6)
Print spooler problem (5)
EVGA 9800 gtx help with finding a g.. (6)
Mysterious Boot manager (9)
Foreign voltage (6)
What OS for a home server? (other tha.. (0)
Need hard disk drivers (3)
Asus P4G8X Mobo (0)
windows vista security holes (0)
EVGA 9800 gtx help with finding a goo.. (6)
hybernate option (2)
blender help (2)
Hard drive freezes boot (1)
