Problem with Dell connection to video projector
Currently Active Users: 1467
Discussions: 200,931, Posts: 2,379,162, Members: 246,297
Old February 26th, 2005, 11:28 PM   Digg it!   #1 (permalink)
I have a Dell Inspiron 4100 running Windows 2000. When I connect it to my video projector, it will only feed the video to the projector when the laptop is in the blank screen mode. When the image is on the laptop screen, there is no image to the porjector. The projector is an Infocus 870 (I think that's the model). I have downloaded the latest Infocus driver and the latest Radeon Video driver for the laptop. But that hasn't helped.
I need to be able to see the computer screen when making a presentation, since I am looking at the audience and don't want to be looking back over my shoulder at the projector image.
Any suggestions?
Thanks.
docbk is offline   Reply With Quote
Old February 26th, 2005, 11:31 PM     #2 (permalink)
Send a message via AIM to fourthbean
Laptops have a key combination you can press to change certain modes for dual screen. It is something like fn (function) F8 or one of the other "f's". Its something you might try.
fourthbean is offline   Reply With Quote
Old February 27th, 2005, 01:36 AM     #3 (permalink)
SpaceSquad's Avatar
Send a message via MSN to SpaceSquad
On some laptops, like mine, you can right click on the desktop and they'll be a "graphics" option (or similar), you can then choose your display settings. Make sure you select "clone" or something like that - this copies the output to the laptop to the projector.
-Space
SpaceSquad is offline   Reply With Quote
Old February 27th, 2005, 02:17 AM     #4 (permalink)
Xtreeme's Avatar
Is the video ati-s3 nvidia or what? If ATI right click desktop go to properties, advanced, go to monitor. Now click the pj that should be showing there (under the main monitor). IT will be red now-click it on, it will be blue tab. Now its active.
http://goatee.net/reviews/dell/inspiron-4100.html
Its ATI video-follow my instructions.
Xtreeme is offline   Reply With Quote
TV tuner cards and VCRs M_Six Graphics Cards and Displays 9 March 27th, 2004 12:16 PM
laptop, tv-out, 15 pin adapter scootmandoo Graphics Cards and Displays 5 July 27th, 2003 03:07 PM
TIME SENSITIVE help please! answer before 1230 pacific! johndisko Technical Support 37 November 14th, 2002 11:32 AM
Runs fine on slower pc with less ram. Choppy on faster w/more ram Pacocase General Gaming Discussion 7 November 13th, 2002 10:02 PM
Dual video cards on Win98SE viztech Graphics Cards and Displays 2 March 17th, 2002 02:01 AM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
