Mobile Power (Battery design?)
Currently Active Users: 1560
Discussions: 200,933, Posts: 2,379,175, Members: 246,298
Old April 29th, 2005, 01:10 PM   Digg it!   #1 (permalink)
Hello all,
I read a post made about rebuilding laptop batteries, and since folks seemed to have some understanding, i figured this would be the right place to turn.
I'm about to start a project for myself, trying to build a nice mobile system. Something to let me have my digital media from the house with me on trips. I'm gonna be using a Mini-ITX setup, and i am planning on trying some kind of battery pack for it. How i'm gonna case this whole thing together will be based upon how i'll have to set up the power grid for this little bugger.
For the test, i was considering buying a battery pack and the charging circuit, and using a laptop as a reference for the interface to the board. I can get a DC to DC converter for the motherboard. Because the whole system will function on like 60W or even less (though i wanted to have 90 as a target, but that's beside the point), i wasn't too worried about the potential output of the power system, just the ability to sustain a charge for a while.
I can purchase an AC->DC brick that will just plug into the motherboard, so if i can't use it without AC, that's not a HUGE problem, it's just a step away from the design goal.
So, what all would i need to stuff into this computer to make it work without a wall? Obviously a battery (LiIon, presumably), and the charging circuitry, which (i assume) will allow the system to run off a wall plug when available.
I don't know how clear i am, as my writing follows a wandering mind a lot.
Obviously there are a lot of places i don't understand (i don't know HOW a charger can interface with a motherboard, for instance), so i'll be a bit of a sponge for a while here, but thanks in advance to anyone who can offer help.
For anyone interested in or confused about Mini-ITX can check it all out here:
http://www.viaembedded.com/index.jsp
Franco
Franco523 is offline   Reply With Quote
Toshiba Satellite 1755 Battery Power Problems Comptech_69 Technical Support 4 September 8th, 2005 11:38 PM
battery, power setting question toreishi Technical Support 1 October 21st, 2004 06:47 PM
cell phone accessories,mobile phone lcd,mobile phone battery pack,cell phone data cab crida Mobile Computing 1 April 11th, 2004 09:19 AM
battery or power supply???? robin801 General Tech Discussion 5 April 4th, 2004 01:45 PM
Centrino Mobile Vs. Pentium 4 Mobile NicRuf Mobile Computing 3 February 22nd, 2004 05:07 PM
Is It Just Me? (2878)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
CPU fan stops spinning randomly (1)
Wireless Televisions. (1)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
