Dell Inspiron 2500 problem
Currently Active Users: 2100
Discussions: 200,948, Posts: 2,379,384, Members: 246,309
Old May 5th, 2005, 12:47 AM   Digg it!   #1 (permalink)
Send a message via AIM to m1a1x1s
Angry
I am trying to fix my buddies Inspiron 2500 and during windows reinstallation the screen started to flicker...exactly like if you were to put your monitor up to a resolution it couldn't handle. I turned it off and it keeps on doing it when i turn it back on. Can anyone tell me how to make it run normal again??!!! Do you think maybe a connection or something got loose...the installation is xp and it was at the last 23min left (after being there for like 45min)
Max
m1a1x1s is offline   Reply With Quote
Old May 5th, 2005, 12:51 AM     #2 (permalink)
did you let it keep installing or did you stop it while installing??
I think it is normal for it to flicker etc when it gets to a certain point of the install...
if I were you I would boot from the cd again and try to reinstall windows again
Old May 5th, 2005, 12:57 AM     #3 (permalink)
it started the flickering and i hit the power button for 6 sec until it shut down, when i turn it on it flickers, and then the screen is unreadable, it is all blue and has a stripe with black lines going down it perpendicularly..... hope it's not fried, that would really really not make my day lol
Old May 5th, 2005, 12:59 AM     #4 (permalink)
what about safe mode?
what about if you boot from the cd?
Old May 5th, 2005, 01:02 AM     #5 (permalink)
can't even get to it, the screen is flickering, although when i hook it up to an external monitor you can see the screen on the monitor, but still blue and flickering on the lcd
Old May 5th, 2005, 01:19 AM     #6 (permalink)
dunno dude..sounds bad....have you checked dells site and/or google for any related issues?
is it under warranty? lol
JP
Old May 5th, 2005, 04:12 PM     #7 (permalink)
lol i doubt it, i took the lcd out and when you move the connector the image comes back, but the install still takes forever, it like gets stuck on 39min now, any ideas?
Old May 5th, 2005, 04:32 PM     #8 (permalink)
well I was going to suggest to check the connector....but I am not sure about the stalling install...if you havent tried it already I would for sure take out any pc cards etc while installing
Old May 5th, 2005, 11:24 PM     #9 (permalink)
all pc cards are out, and even again.....it still stalled, this is after 3 times of trying, i think that the cdrom might be a little old... i've had this problem on older cdroms, they just lock up for some reason....although it is past the copying part, do you think maybe a virus could be causing this? or maybe bad ram?
Old May 5th, 2005, 11:28 PM     #10 (permalink)
hard to say..and its harder with laptops since it is harder to switch parts etc
you can check the ram with something like memtest86 it makes a boot up floppy and you let it run overnight
OS reinstall problem -dell inspiron 3500 Arjay13 Mobile Computing 7 May 5th, 2008 03:14 PM
OS reinstall problem -dell inspiron 3500 2afestic Mobile Computing 6 June 30th, 2003 08:03 PM
Dell Inspiron 2500 Keyboard problem skybolt_1 General Tech Discussion 5 June 5th, 2003 06:55 PM
Dell Inspiron 4100 LCD problem SeanC Mobile Computing 2 May 20th, 2003 09:55 PM
FS: Dell Inspiron 2500 $650 + half of shipping This is a nice deal. PICS INSIDE!!! grandchehaw Traders Forum: Buy, Sell, Trade 5 December 21st, 2002 05:37 PM
Making Health Care Worse (169)
The disrespect of Obama by Russian .. (20)
Is It Just Me? (2934)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
