Hi there. I have a laptop, but the monitor broke on it. My brother decided to take the monitor off to try to fix it. It ended up breaking, now I can't get the laptop to work. Well, I dont know if it works. Is there any way to plug a monitor to the back and see if it will work? I tried that, and pressed the button that usually works to make it dual screen, but I think the laptop is not even loading windows because there is no monitor. Do you understand what I'm saying? If not, I'll try to be clearer...
