ok, so i put my laptop in hibernate and took it down to my brothers house. when i got down there it wouldnt connect to his wireless connection. i have never had problems before and his laptop is working so it must be some setting on my computer.
I have a Dell E1705 with the dell wireless card built in.
if i double click on the signal bar, it shows his network and i can go through the steps to connect to it, but nothing happens
if i go under network connections, then under my wireless connection, it says that it is unable to configure.
things I have tried:
restarting/rebooting/rehibernating
system restore to yesterday and then again to last week
disable and enable connection
repair connection
any suggestions?
