connecting laptop to tv using s-video cable
Currently Active Users: 2598
Discussions: 203,415, Posts: 2,407,361, Members: 248,939
Old January 6th, 2007, 12:47 PM   Digg it!   #1 (permalink)
i have recently purchased an s-video cable to connect my laptop to my tv.. i have a dell inspiron 640m laptop. I read through some tutorials on how to connect it and what settings to change... i changed the graphics card settings to both tv and monitor using dual settings.. and the picture is displayed on my tv... however it is displayed in black.. can anyone help???
username123 is offline   Reply With Quote
Old January 6th, 2007, 07:42 PM     #2 (permalink)
what do you mean it's displayed in black?...like you can't see anything?...also...I think you would get better quality if you used a component cable like a monster instead of a s-video cable...<.<...
xbanhcuonx is offline   Reply With Quote
Old January 6th, 2007, 07:50 PM     #3 (permalink)
dvi>svideo
that is if your tv and laptop have dvi
but if your tv and laptop are fairly new
chances are theyll have them
Kphu is offline   Reply With Quote
Old January 7th, 2007, 02:07 PM     #4 (permalink)
the picture is showing on the tv screen and it is crystal clear... but it is in black and white. i have read some tutorials and i think it may have something to do with the format of the video card being set to NTCS and the format of the tv being PAL. i am trying to change the format to PAL but i cannot find the device manager for the video card. i have looked through all the display window tabs and advance settings.
what is DVI cable.. the laptop is only 1month old so it could have DVI socket but i dont know what it looks like.
Old January 7th, 2007, 06:10 PM     #5 (permalink)
Old January 7th, 2007, 06:20 PM     #6 (permalink)
Vyx
Vyx's Avatar
Send a message via AIM to Vyx Send a message via MSN to Vyx Send a message via Skype™ to Vyx
Your laptop only has a VGA (15 pin) and an S-Video port so you wont be able to hook it up via DVI.
On a side note, most notebooks only come with a VGA port, DVI is for the most part only on higher end gaming notebooks.
Gi | Yuu | Jin | Rei | Makoto | Meiyo | Chuugi
Vyx is offline   Reply With Quote
Old January 7th, 2007, 07:04 PM     #7 (permalink)
Banned
Keymaker's Avatar
Send a message via ICQ to Keymaker Send a message via Yahoo to Keymaker
You should see something there under the video card's settings for changing to PAL.
Is the video card using the ATI driver like it should? If not, go to Dell, support and download the display driver.
http://www.dell.com/content/products...n=specs#tabtop
BTW, DVI could be used with a VGA to DVI adapter, but won't get the capabilities of DVI with it.
Keymaker is offline   Reply With Quote
Old January 10th, 2007, 04:34 AM     #8 (permalink)
"keymaker" i do have a display driver - some intel 945GR mobile or something but the options i have in that diver menu are no-way near as detailed as the one in your thumbnail... all i have is "general" "adapter" "monitor" "troubleshoot" and "color management"
i'm going to email dell and get some help off their support.. i'm paying for some three warrenty so they had better help me! lol.
anyway thanks for everyones help i really appreciate it!
regards.
Old January 10th, 2007, 06:05 PM     #9 (permalink)
Banned
Keymaker's Avatar
Go to Dell's website. Click home and then you will see tabs above the web page, click support and find your drivers.
Better yet. I believe this is your laptop. Be sure to have JS on.
Oh wait, crap, I see the Intel 945. I think you won't have an ATI then. You can confirm this by Dell's current configuration checker. Have to use IE in order for that to work. Firefox can't be used.
Another way is to type dxdiag into RUN under the start button. Click the display tab in dxdiag.
Old January 30th, 2009, 08:29 AM     #10 (permalink)
Black & White display on TV
I had the same problm. I was using s-video to rca convertoe cable. Using the same cable with my DVD player gave me color; but when i hooked that up with my laptop it showed black & white on tv. I was very sure that the cable is fine and somethings wrong with the setting.... but u know what i was wrong. Its actually the cable. the internal connections for the s-video cable that is used for laptop is different. Just purchase that one and ur problems will be solved. another solution that might work read it in some post....havent tried it though ...
"fixed it using a solution i found on a random forum somewhere (can't remember which one), which is to wrap a little wire around the top 2 connectors (with the plastic plug bit at the bottom) on the svhs cable, joining them together. apparently this is the difference between svhs and composite or something. pretty dodgy, but it works ok now so i'm gonna leave it alone. now i can play dawn of war on my tv! yay!"
danish.faraz is offline   Reply With Quote
S Cable - Connecting laptop to tv monitor coopersveronica Mobile Computing 73 January 7th, 2010 06:55 PM
connecting rca to s-cable opus358 General Tech Discussion 3 June 29th, 2005 10:19 AM
connecting 2 PCs via cross-over cable olufsen Networking and Internet 14 January 23rd, 2005 06:59 PM
Help... laptop and s-video cable problems. lostotaku Graphics Cards and Displays 2 November 13th, 2004 02:11 PM
Problem connecting s-video to tv from ibm A22m laptop. dabooj Mobile Computing 0 September 30th, 2004 11:29 AM
Is It Just Me? (3716)
nVIDIA GTX 260 vs ATI 5770 (5)
Superbowl commercials (The green po.. (15)
and she wanted to be VP? (42)
GPU upgrade from 8600 GT (11)
New PC Heavy Gaming Rig (8)
[F@H Chat]2/6/10 New thread for ya'.. (22)
Need for Speed Shift (7)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
Graphene transistors promise 100GHz.. (7)
I want to buid a pc with this case (14)
Animated GIFs don't animate? (13)
Upgrading (5)
Microsoft Wireless Keyboard 3000 (13)
Laptop - HDTV Connection Using HDMI C.. (2)
How Good is This $450 MSI Laptop? (3)
HD5870 Question (16)
[F@H Chat]2/6/10 New thread for ya' s.. (22)
Wireless G printer w/wrt160n (0)
SpeedFan Temp Monitor Help (3)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
should i upgrade whole pc or just vid.. (2)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
Wii at buy.com for $374 - Carnival Sm.. (7)
Deleted email addy keeps bouncing bac.. (1)
Video Format Total Solution: How to C.. (0)
wireless connectivity (0)
