temp volt monitor
Currently Active Users: 2098
Discussions: 200,959, Posts: 2,379,531, Members: 246,329
Old July 7th, 2007, 07:44 PM   Digg it!   #1 (permalink)
proffit's Avatar
temp volt monitor
well i have asked this question many times in the past but never response. does any one know a good program that will allow me to monitor my cpu and graphics temps on my laptop ( maybe ram aswell if possible).
ive just been a little concerned cause im back in aus and dont want my new laptop to fry in the heat here. normallarely i wouldt be concerned with heat in a laptop but this one gets big hot spots in it, since its running a 8800 i can understand why. so please help me out a little dont let my new baby fry.
if it is not broken, play with it till it is.
proffit is offline   Reply With Quote
Old July 7th, 2007, 08:17 PM     #2 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
I use Speedfan myself. It works well..
U could use Nvidia's utility for the GPU. But i would think speedfan would pick up the sensor in the GPU also...
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old July 7th, 2007, 08:33 PM     #3 (permalink)
proffit's Avatar
sorry forgot to mention i have been made vista's bitch so it needs support for vista. ( nice way to ruin a very nice lappy ey? )
thanks for the response karma
Old July 7th, 2007, 08:38 PM     #4 (permalink)
\m/(°-°)\m/
Damn Vista.....
I have no idea then. I'm retarded when it comes to Vista..
Old July 7th, 2007, 08:48 PM     #5 (permalink)
JLK03F150's Avatar
Send a message via ICQ to JLK03F150
How about Core Temp (provided you have a C2D CPU) & Rivatuner?
I'm not a Vista user, so I don't know if they are both compatible.
JLK03F150 is offline   Reply With Quote
Old July 8th, 2007, 03:56 AM     #6 (permalink)
proffit's Avatar
yes it is a core 2 duo. ill check out riva tuner.
thanks forh te responses.
for the record we are all retarded when it comes to working out what will work with vista.
head my warning if you see the work vista run the other way.
if you see the word windows cautiously walk away.
Old July 8th, 2007, 12:11 PM     #7 (permalink)
JLK03F150's Avatar
This is an interesting Vista tip that may be helpful...
before the operating system boots press F8 like you were going to boot into safe mode, then instead select the disable driver signing enforcement, and that should fix all your problems, this also makes atitool work properly
Speedfan for CPU temp monitoring is supposed to work with Vista 32, but may have issues with 64.
Rivatuner for GPU temp monitoring is listed as having "limited feature set available" with Vista.
Monitor CPU Temp......... Network67 General Tech Discussion 8 December 31st, 2004 03:35 AM
1.5 Volt 3.3 Volt AGP Vid Cards. RustyGT Graphics Cards and Displays 2 May 21st, 2003 08:41 AM
Temp monitor iNeb PC Modification 7 January 18th, 2003 02:57 PM
Temp Monitor Brainchild Processors, Memory, and Overclocking 4 January 17th, 2002 10:50 PM
temp monitor jfwy Processors, Memory, and Overclocking 3 December 2nd, 2001 05:07 PM
Is It Just Me? (2969)
The disrespect of Obama by Russian .. (42)
Making Health Care Worse (179)
Print spooler problem (16)
Nvidia GTX 260 problem (0)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
