Hi,
I have a Compaq nc6220. The battery used to last for about four hours. Now it will only hold about a 30 minute charge. I assumed that the battery was bad, so I changed it, but still got the same results.
Modifyhing the settings under Control Panel>>Power Options>>Power Schemes, don't make any difference.
I assume that there is a power controller that determines how much the battery charges, etc, but am wondering if there is anything I can do to try and reset it or whatever, to see if I can get this to work.
Does this make sense?
Any ideas?
Thanks,
