June 18th, 2009, 02:02 PM #1
Two slight problems with my laptop
(It's an Acer Extensa EX4420-5239.)
(1) The Synaptics Pointing Device has a middle button which serves as a 4-way scroll control (you can see it in the pix at the link), but it's stopped working. Device Manager says that the device is working properly. What to do to fix this?
(2) Each time I boot up I now get a message saying that ATI Catalyst Control is not available and that I need the latest drivers -- which I have, according to Device Manager. What to do to fix this?
In judging a two-person singing contest, never award the prize to the second soprano having heard only the first.
-- Francis Bator
June 18th, 2009, 04:26 PM #2
for problem 1 have you checked the settings in control panel it may not be enabled although the device manager says it is working probably just means it is not faulty
as for problem 2 have you downloaded ati ccc direct from ati it should overwrite the existing drivers and the catalyst control centrethere's someone in my head but its not me
Slight Color Problems with New LCD's Normal?
By El Burro in forum Graphics Cards and DisplaysReplies: 0Last Post: July 16th, 2006, 10:55 AM -
still got slight vid card problems !!!!
By valos1479 in forum Graphics Cards and DisplaysReplies: 17Last Post: July 8th, 2006, 09:41 PM -
How can I get the slight dents out of my car?
By Martoch in forum IMO CommunityReplies: 24Last Post: October 11th, 2005, 06:09 PM -
Slight Problem
By Terminal23 in forum IMO CommunityReplies: 4Last Post: November 26th, 2003, 11:03 PM -
slight install prob RH 7.2
By brunix in forum Applications and Operating SystemsReplies: 4Last Post: March 12th, 2002, 12:11 AM
Hi If you installed Avira Antivirus correctly before, the above step should help you uninstall it successfully. Click Start menu and go to Control Panel.
How to remove Avira AV from Win 8?
