Hitachi Lap Top Problem
Currently Active Users: 1554
Discussions: 200,925, Posts: 2,379,128, Members: 246,291
Old May 31st, 2002, 06:18 PM   Digg it!   #1 (permalink)
chefde's Avatar
I was given a Hitachi E133DN.
It has no OS & no cd-rom drive.
In order for an external cd-rom (PCMCIA) to work I need at least Win 95 loaded.
Any suggestions on how to get Windows on this machine?
P133
16 MB Ram
3 1/2 Floppy
1 Gig Hd
No NIC
No Internal cd-rom capability
slot for 2 PCMCIA II or 1 PCMCIA III, don't know if it's 16 bit or
32 bit.
Thanks for any help,
Chef
chefde is offline   Reply With Quote
Old May 31st, 2002, 06:29 PM     #2 (permalink)
A hero in training
GroundZero3's Avatar
boot up to a floppy disk that has a win98 disk
www.bootdisk.com
have you tried that?
GroundZero3 is offline   Reply With Quote
Old May 31st, 2002, 06:38 PM     #3 (permalink)
chefde's Avatar
Hey GroundZero3,
I have a win98 bootdisk but I don't think it will recognize a PCMCIA CD-rom drive.
I don't have one & don't want to buy it if it won't work.
Hitachi support says it won't work.
They said to buy Win95 on floppies!
Chef
Old May 31st, 2002, 07:43 PM     #4 (permalink)
Good Companion's Avatar
Chef:
I've got one of these laptops myself, and on mine the ram is upgraded to 32MB. I tried to put Win98SE on it and it ran like a dog. In fact, it ran so slow I reformatted and put Win95 back on.
Back to your original question, I bought an external CD-ROM from a friend to install the OS. I don't know if you can buy a cheapie NIC and have it install under dos.
I would try to find someone with an external and borrow that.
Dana
Good Companion is offline   Reply With Quote
Old May 31st, 2002, 07:48 PM     #5 (permalink)
caddmannq's Avatar
Or swap your HDD into another machine, copy a Win95 CD image onto it, and install from there? You'd have to partition the HDD, but I think that will work.
Beware the Penguinator!
caddmannq is offline   Reply With Quote
Old May 31st, 2002, 08:32 PM     #6 (permalink)
chefde's Avatar
Thanks for the ideas,
have to go play Chef!
Chef
Old May 31st, 2002, 08:56 PM     #7 (permalink)
Uncommon Man
samwichse's Avatar
well, the win95 directory on that CD contains the entire install. The CAB files seem to be 1.6MB apiece, so if you formatted a bunch of floppies with one of those utilities that could format disks a little bit larger, then you could put each cab on a disk and copy them all to a win95 directory on your c: drive on the laptop. That might take a bit of work though...
In fact, this article indicates this is exactly how win95 on floppies came:
http://www.byte.com/documents/s=204/BYT19991103S0010/
I used to use one of those programs back when I would log my 386/16 with 8 meg of ram to log onto a local BBS .
Sam
samwichse is offline   Reply With Quote
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
