Results 1 to 2 of 2
    Jun 2010
    4
    Hard drive upgrade help on HP compaq 6910p
    the laptop currently has a 80gb 5400 drive which it's hard drive interface is 1 x 7-pin Serial ATA/150 Serial ATA
    Seagate Momentus 5400.3 2.5IN 80GB SATA 5400RPM 8MB Notebook Hard Drive OEM - DirectCanada
    i want to upgrade it to 320gb 7200 drive which it's hard drive interface is 1 x 7-pin Serial ATA/300 Serial ATA Newegg.com - Western Digital Scorpio Black WD3200BEKT 320GB 7200 RPM 16MB Cache 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive -Bare Drive
    any advice on that? will it fit well?
    also is it possible to upgrade the graphic somehow is there extra room for another card? cuz years ago they had a option to choose to have ati x2300 i think. now it's running on intel GM 965 chipset graphics.
    other than that the laptop is running on win7 32bit ultimate 4gb of ram and t7300 duo core at 2GHz.
    P.S will Newegg.com - D-Link DWA-652 Xtreme N Notebook Adapter fit in my laptop since my router on the desktop D-Link DGL-4500 IEEE extream N and will i notice a boost in terms of speed or lag?
    thanx in advance
    South Jersey
    11,368
    SATA should be backward compatible, so an SATA II drive will work in an SATA I system.
    You CANNOT upgrade integrated graphics.
    A wireless N adapter will only work if you have a wireless N router.
  1. Compaq Presario 5461 - New Hard Drive
    By jrichar9 in forum Technical Support
    Last Post: September 4th, 2007, 09:12 AM
  2. Compaq Laptop hard drive failure
    By Tenor in forum Storage Related
    Last Post: February 21st, 2005, 06:45 PM
  3. compaq presario 5724 replacing old hard drive
    By node572 in forum Technical Support
    Last Post: September 22nd, 2003, 12:59 AM
  4. Compaq presario 1200 hard drive replacement
    By GroundZero3 in forum Technical Support
    Last Post: September 13th, 2002, 02:34 PM
