Results 1 to 2 of 2
    Mar 2010
    Ontario
    159
    Laptop Replacement Fan?
    I have a Asus RoG laptop and it doesn't do very well with heat. I recently had to have the motherboard and video card replaced (luckily under warranty) right during the middle of exams, which was annoying to say the least.
    Just from the way the laptop normally runs, I suspect that overheating might have had something to do with why the parts died like they did. Every store I went to (factorydirect, tigerdirect) seemed to think replacing laptop components "wasn't worth it" somehow, but still is there anywhere I can find higher performance fans for my laptop?
    May 2006
    Alabama
    451
    There may be.. but I know the "laptop coolers" that are rigid and fit under the laptop, keeping the airflow unblocked and that have built in fans, will cool it considerably. I've seen mine drop 10 or more degrees with one.
  1. GPU fan replacement
    By cksboy15 in forum General Tech Discussion
    Last Post: February 2nd, 2009, 12:40 AM
  2. gpu fan replacement
    By lancethepants in forum Graphics Cards and Displays
    Last Post: March 13th, 2008, 02:16 PM
  3. Card fan replacement
    By Vagabond in forum Graphics Cards and Displays
    Last Post: November 2nd, 2006, 12:16 PM
  4. psu fan replacement
    By notauser in forum Technical Support
    Last Post: February 9th, 2004, 12:44 PM
