Thread: Nvidia 8600m gs problem. Help!!
September 16th, 2010, 07:01 AM #1Member
- Aug 2008
- 54
I've Fujitsu Siemens amilo xi 2428 with nvidia 8600m gs.
After two years of purchasing (warranty expired) the graphics card broke down showing artifacts and freezing the system in welcome screen.
I did the oven trick 2 times:
the 1st time the graphics card lasted 3 days then broke down again.
i repeated the oven trick and used a cooling pad and the graphics card also broke after three days!
in the three times, the card broke while playing games (but not very intensive ones)
What could be the problem?! Should I heat it above 200c (385 F) or leave it for longer time?Is there another fix? (the replacement card is too expensive).
please help!
September 16th, 2010, 02:19 PM #2
The Oven trick is not a guaranteed fix, its only meant as a short term fix until a replacement can be had.
Same thing applies for Xbox 360 owners and the Towel Trick, or Baking a Video card for Desktop PC's, its not a permanent fix, and may only work for a few minutes to few days to few weeks, or months, but its not permanent, and varies for each user.
the ONLY somewhat Guaranteed fix is to Replace the Card or Chip, simple as that.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
cost of NVIDIA GeForce 8600M GT
By techoman in forum Technical SupportReplies: 5Last Post: January 3rd, 2010, 06:22 AM -
By techoman in forum Graphics Cards and DisplaysReplies: 2Last Post: January 3rd, 2010, 05:29 AM -
GeForce 8600M GS
By Semir in forum Graphics Cards and DisplaysReplies: 0Last Post: October 27th, 2008, 10:05 PM -
8600M GT clocked to an 8700M GT?
By Player_13 in forum Graphics Cards and DisplaysReplies: 1Last Post: July 10th, 2007, 04:59 PM
Well this little lady is off to bed! Goodnighters!
