September 23rd, 2010, 10:42 PM #1Junior Member
- Sep 2010
- 2
Dell Inspiron 1502 Power adapter light goes off
Hello,
I came to the post linked below as I have a similar problem:
Possible solutions for burnt-out circuitry on Dell Latitude D505 mobo?
I have the same problem with a Dell inspiron 1520, when I connect the power adapter to the wall plug the green led lights on, but as soon as I connect it to the laptop the light turns off.
I have ruled out the adapter being a problem as I tested it on another inspiron 1520 and it works fine, while another adapter does the same on the "bad" inspiron 1520.
I opened and removed the motherboard, it has 5 capacitors PC1 to PC5 close to the plug for the power adapter and they all seem fine with resistance of 0.5kohms to 250kohms. I then checked the PC capacitors close the the connector for the battery (it has like 20 with the "PC" mark) and at least half of them show a resistance of 1.3Ohms.
Is that normal or with such low resistance I can consider them as being in short circuit?
Any ideas on what else to look at? Or maybe the mother board is beyond repair?
Thanks in advance
June 20th, 2012, 05:14 PM #2Junior Member
- Jun 2012
- 1
November 1st, 2012, 12:35 PM #3Junior Member
- Nov 2012
- 1
Please reply
Hi
I dont know what else to look for in this problem. Anybody please suggest what could be wrong?
Nag
Dell support centre dsc.exe messing up dell inspiron 1300
By dmdougie in forum Technical SupportReplies: 2Last Post: November 18th, 2009, 08:30 AM -
Dell Inspiron Ac adapter help
By deathrail in forum Technical SupportReplies: 1Last Post: April 20th, 2006, 11:18 AM -
DELL Inspiron B120 >> Only For $499 at DELL
By packer99 in forum Networking and InternetReplies: 0Last Post: January 3rd, 2006, 08:46 AM -
power light ?
By blackezed in forum General Tech DiscussionReplies: 6Last Post: January 15th, 2005, 02:44 AM -
Inspiron 8200 car/airline adapter
By VHockey86 in forum General Tech DiscussionReplies: 2Last Post: January 21st, 2003, 07:22 AM
Qualcomm is demonstrating its latest Mirasol display technology with a 5.1" panel packing 2560x1440 pixels of resolution.
Qualcomm Demos 577PPI Mirasol...
