Thread: Compaq C700 Power Problems
May 22nd, 2011, 01:01 AM #1Junior Member
- May 2011
- 3
I recently replaced a bad lcd cable in a Compaq Presario C700 for a friend. When I booted it to test the display everything worked fine for about 20 minutes and then it shut off. I initially thought it was a cooling issue because it was running pretty hot. I let it sit for a couple hours and switched it on again. It ran for 5 minutes and then shut off. I went to plug the power supply into the laptop and the power led wouldnt even come on. When I took the plug out of the laptop upon closer inspection I realised that I could here a slight crackling noise when playing with the plug on the power supply. There was apparently a short in the power suppy that neither of us were aware of. I went to try a working power supply by the exact same company and it was the same voltage rating and it wont even show that it is recieving power. I opened it up and there is no visible damage to the board and the jack itself is firmly connected. I need some troubleshooting suggestions as far as how to narrow it down further from the jack, battery, and motherboard preferably least expensive to most. I have access to all replacement parts individually and have the technical knowhow to replace them.
presario c700 laptop
By Mikenmiami09 in forum Technical SupportReplies: 1Last Post: May 25th, 2009, 04:53 PM -
Compaq Laptop Power problem
By kovan in forum Technical SupportReplies: 1Last Post: September 14th, 2007, 02:10 PM -
Compaq Armada doesn't power off
By effendi in forum Mobile ComputingReplies: 5Last Post: December 1st, 2003, 03:29 AM -
Compaq power supplies
By Cyberlore in forum Technical SupportReplies: 19Last Post: April 26th, 2003, 10:14 PM
Has it occurred to anybody in the Quantitative Easing and Easing crowd that we have a Stock Market recovery but not an Employment recovery because we don't have the reinvestment in our own Economy...
