Results 1 to 4 of 4
    Dec 2011
    bay area
    50
    Problem with iTunes/iPhone 3GS
    Hi,
    After the OS5 update for my iPhone3GS/iTunes. I've been experiencing some really annoying issues..
    I either get the error code "0xE8000065" or my iTunes goes "not responding" forcing me to Start Task Manager and click on End Now (sometimes a pop up will come up telling me to end it or wait for it.. and when I wait for it, it doesn't help... it freezes the whole computer so I have to end the program.
    And another way to "fix it" is to unplug my iPhone and plug it again.
    This happens to be everyday!!
    So how can I fix this?
    My iPhone is not jailbroken, I dont use illegal stuff and all of my apps are either free or those free for a limited amount of time.
    I really want to get this fixed like it used to be before..
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    I wonder if reinstalling itunes will help.
    Frick tony_j15's Avatar
    Mar 2003
    Joplin, MO
    14,127
    Is your PC a Dell? There is a bug where some Dell's USB drivers don't work with iTunes that can be solved by using a USB hub or PCI USB card.
    Here's two solution pages:
    iTunes error fix
    iTunes solutions
    Good job, friend-of-friends!
    Dec 2011
    bay area
    50
    I re-installed iTunes twice and didn't help.
    The laptop im using is a Sony Vaio... sometimes when i connect it, to go to my iphone's pict folder, it will not load properly and I have to disconnect and connect again to be able to go to my computer>iphone>internal storage>DCIM to see my pictures.
  1. iPhone 3GS 32gb
    By waynezo in forum Mobile Computing
    Last Post: August 18th, 2009, 07:10 AM
